Adding Zerk to mandrel
/ Adding Zerk to mandrel #1
Syncro
Platinum Member
NW Nevada
MF 1532, Kubota B-26 TLB
Thought I'd pass this on for those that may have an interest. The mower blade mandrels on my lawn tractor have sealed bearings, which have worked very well for the past 13 seasons, however lately one has been getting a little noisey. Since there is no way to grease the bearings, I was going to replace the whole mandrel until I found out the price, $87 plus tax! Each! So I thought I'd add a zerk and see if I could get some grease in to the dry bearings. All that was required was drilling and tapping a hole in the rather thick aluminum casting, turned out to be pretty simple. I then added a few squirts of oil, screwed in a new zerk fitting and filled the cavity with grease. That seemed to do the trick just fine, grease was reaching the bearings from the inside and a smooth quiet mandrel was the result.
/ Adding Zerk to mandrel #2
Syncro, a few thoughts from a smalltime lawn mower repairman. The sealed bearings are just that sealed. In time the life of these bearings are up. Usually the seal gets comprimised & water finds it way in. I believe the grease has temporarily quieted the bearing noise. Those bearings are replaceable for about 6 bucks each. Loosen the top nut to the top of the threads & drive the shaft out. The bottom bearing is a little harder to get off. Usually the top bearing is fine. That said the grease thru the zerk fitting with new bearings surely can't hurt. In fact, I have seen a replaceable shaft for an AYP mandrel assembly now has a zerk on top of the shaft. Shaft is drilled so that grease can enter the top & drilled again so it can come out inside the mandrel assembly.
Thanks Ron, thats good to know. If I keep the machine into next season I'll replace the bearings. Problem is the Briggs 18hp horizontal twin has started making a rather loud clatter. In your experience in repair, any ideas why the motor is suddenly getting noisey? I estimate it has ~350 hours and I've always changed the oil twice a season. In any event the mandrel will become moot if the engine blows up!
/ Adding Zerk to mandrel #4
Syncro - the bearings on that have a seal on both sides, so the grease wount really enter the bearings.
If you take the shaft out as described above, replace the bearings, it isnt that hard, and cheap. When you put the new ones in you could take the inside seal out, so the grease will enter the bearings. Or, just leave them as sealed bearings, it'll last several more years.
As to the engine, is it down on power atall. Is it running on both cylinders. Change the oil, looking for metal filings in the oil
/ Adding Zerk to mandrel #5
Synchro, as you know, internal engine noise isn't good. Can't really give much of an opinion without listening myself. Could it be external, like muffler or a shroud bolt came loose? From your picture, I can tell you take extra good care & changing oil twice a year is way more than most. Like Mith asked, how is the power?
It runs strong, smooth powerfull rythim from the exhaust and it starts right up. No smoke, no oil consumption, no metal in the oil. Its got me baffeled. The clatter is pretty loud and sure seems to be internal. I tried different weights of motor oil from lighter to heavier viscosity, no change. The loudness seems to quiet some as the enghine heats up. I sure hate to run a machine this way, but really have no choice. The local lawn repair guy says parts are not available, just a whole new engine. Its been a good mower, never abused, and I really thought it'd last forever, kinda concerned that it may be on its last leg. Also makes me wonder about Briggs.
/ Adding Zerk to mandrel #7
Another point for future reference if you'd like. My 14 year old MTD 42" wore out the spindle bearings this year also. First place I found online wanted about $70 ea. After finding many other offerings, in declining price, I found an eBay seller that had them all day every day for $17 ea. (After I ordered off eBay, then I found the current AgriSupply catalog had them for $17 also.)
For $17 ea, I decided to get bearings later and rebuild a spare set when I'm bored someday.
Kindof hard to imagine that parts cannot be had for that old Briggs motor ...
/ Adding Zerk to mandrel #8
Syncro said:
The local lawn repair guy says parts are not available, just a whole new engine. Also makes me wonder about Briggs.
Get your MN & type number off the engine shroud. Go to the Briggs site & put the numbers in. Then go to a parts site like this site & put the parts numbers in. I doubt that there isn't much you can't order. As for the loud clatter, if it were a rod you would here more of a knock. It could be a loose valve seat, but then there would be a loss of power & rough running especially under load. What did the the local repair guy say about it? I guess if he said parts weren't available, I wouldn't value his opinion of what the noise was though. Maybe he just didn't want to work on it. Maybe load it up & take it to another shop, if for nothing else other than let the fellow listen to it run & ask him what he thinks it is. (or her).
/ Adding Zerk to mandrel #9
I feel bad now, I did the same thing a few years ago and I think it helped, but after reading about the sealed bearing thing? its kinda of disappointing? Ya know what I mean? LOL
Jim
Molerj said:
.......I doubt that there isn't much you can't order. As for the loud clatter, if it were a rod you would here more of a knock.....I guess if he said parts weren't available, I wouldn't value his opinion of what the noise was though.......Maybe load it up & take it to another shop, if for nothing else other than let the fellow listen to it run & ask him what he thinks it is. (or her).
I think you are right about the local shop guy not wanting to work on it, I got that impression, and as you point out parts are probably out there. I will take it to another shop next week. I was thinking rod bearing too, if thats the case it sure dosen't say much for Briggs as this engine has been babyed since new.
Anyways thanks for the valuable input and have a great 4th, I'll post the outcome.
Syncro said:
I will take it to another shop next week. I was thinking rod bearing too....
Update on the noisey engine.
I was going to take it in to another shop, but after the weekend of the Fourth the lawn really needed cutting so I just said heck with it and ran the mower anyways. I mean if it was a bad rod than it was more than likely not economically feasable to fix. Well.... to my great surprise the engine fired up and the noise was GONE!! To make matters even more confusing I just ran the machine tonight for an hour and same thing, quiet, powerful rumble and not a clack, clatter or knock to be heard. Now either I'm going nuts or there is something strange going on here.
Any ideas? There is obviously something loose in there somewhere, but what? That knock sure sounded seriouis, like a rod bearing or other heavy component, I am at a loss how it could just stop.
Regarding the original thread, the mandrel is still running smooth, so I guess at least some grease made its way into the bearings.
/ Adding Zerk to mandrel #12
Have you checked the cowl to see if it's loose and all the other pieces of sheet metal that direct air to all parts of the engine?? Sounds like something is loose and catching either the flywheel or some other part.
Also, I've never had any trouble getting B&S parts, even for older engines and I've rebuilt many older B&S engines.
I've found some mandrels were fitted by the manufacturers with grease nipples! I replaced the mandrels on an older Murrey, the old ones were sealed, the new ones had zerks on!
/ Adding Zerk to mandrel #13
If it's intermittant, you might get new head gaskets and pull the heads to de-carbon the heads, piston tops and valves. I have to do that every few years as under certain conditions it will sound like the motor is trying to hammer itself apart. No carbon, no noise. Just a thought ... it's easy and cheap.
Cheers!
Cheers!
Thanks for the tip. I didn't think carbon build up could cause such a loud knock, wonder how that happens. One thing that I have always done since the machine was new is run it at about 1/3 throttle, very seldom wide open. so maybe that can cause carbom buildup. :confused: In any event, since it is an intermittant problem and it has not blown itself up yet, I assume no harm is being done running it. I'll try full throttle next time I mow and maybe blow out excess carbon. I used to do that with my old Ford years ago.
John47-
I did check the cowl, etc, but this is not a sheetmetal noise. It sounds internal, I was certain it was a rod bearing before it dissapeared. A loose rod wouldn't fix itself, so the mystery continues.
/ Adding Zerk to mandrel #15
Syncro said:
... In any event, since it is an intermittant problem and it has not blown itself up yet, I assume no harm is being done running it.
Well, yes and no. If it is carbon, and if you can keep it from doing it, then you're probably ok. If it's carbon, when you hear the noise the motor is preigniting/ detonating, which should eventually pound a hole in the piston :eek:
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
7ft Metal Texaco Pump (A65583)
7ft Metal Texaco...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
