Adding tie down points to front of tractor
   / Adding tie down points to front of tractor #21
   / Adding tie down points to front of tractor #22
Actually I had it powder coated the black that matches the others stuff. I like it better then the blue actually.
   / Adding tie down points to front of tractor #23
i like Rams built a 2 inch receiver which I incorporated into my nose - radiator protector.(I had a stick go up an miss the rad but push the loser rad hose off....) On each side I welded hooks. The receiver is used to put my counter weight for when the loader is off and I'm cultivating. This way the counter weights also fit on all of my three point attachments that I have also welded receivers to. Works good with the sod buster to get some extra dig!. IMG_0696.JPG
   / Adding tie down points to front of tractor #24
This is my solution to creating trailer tie down points on a B2650.
   / Adding tie down points to front of tractor #26
I was just thinking...if you drilled and internally threaded a shaft just long enough to be a snug fit between two black plates and threaded the bolts used to attach your hook plates into it, one on each side, it would add a lot of strength to it.
TEST YOUR BID BUTTON! (A57192)
TEST YOUR BID...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
2017 Ford Transit 150 Cargo Van (A55852)
2017 Ford Transit...
2018 Bobcat T750 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T750...
