adding tach to kioti tractor
/ adding tach to kioti tractor #1
frank12345
I'AM LOOKING TO ADD A TACH TO MY TRACTOR DIESEL ENGINE WHAT KIND SHOULD I BUY AND WHERE DO I HOOK IT AND WHERE WOULD I FIND ONE THANKS
/ adding tach to kioti tractor #2
Install a tiny tach Look for the Commercial powered one model DTTNR
Several members here have it on their tractor and it works well for them.
$65.00 and requires a tranducer mounted "around" the fuel line.
/ adding tach to kioti tractor #3
The tiny tach works well, and comes with the transducer to clamp on one of the injector lines, just give them the diameter of the line and they'll send the unit and all the parts with instructions, it's really easy to install.
/ adding tach to kioti tractor #5
Is this the same Kioti that you drop down to 2500 rpm after startup? /forums/images/graemlins/confused.gif
2016 Ford F-550 4x4 IMT 3203i 2 Ton Crane Mechanics Truck (A61568)
2016 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 John Deere 350G Excavator (A60352)
2015 John Deere...
2016 Ford Expedition 4x4 SUV (A61569)
2016 Ford...
2013 John Deere 848H (A61166)
2013 John Deere...
