Adding Remotes to JD950
/ Adding Remotes to JD950 #1
Pinch
PA
JD950, Kubota L4610, Kubota B2620
I have a JD950 (Yanmar) without hydraulic remotes, just a 3pt hitch, no loader. What would I need to add two sets of remotes. Here are some images - click on them to enlarge. Thank you
/ Adding Remotes to JD950 #2
I have attached the instructions for installing the john deere kit, which is not available anymore unfortunately. You may be able to find parts used or you could plumb in a valve of your choosing as long as it is for an open center system. If you have a lower serial number than 12000 you have some differences.
  • 950 scv wo power.pdf
/ Adding Remotes to JD950 #3
The only practical way to do this is to buy the complete system off a salvage tractor. Probably easier to just buy a different tractor. What are wanting to do with the remotes? If you are wanting to add a loader you may not be happy without power steering and 4WD.
Thanks for the advice and thanks to jd110 for the instructions. I want to use a specialized side-mounted implement for hilling up and down. My 950 has only ever been used for mowing but it would be perfect because it fits in the rows. Oh Well
The manufacturer thinks it will work on my B2620 Kubota which is a smaller compact, not so much in HP, but in size and weight. I'm worried it's too light for moving soil
/ Adding Remotes to JD950 #6
Would a PTO mounted pump work for this implement? Might be an option for you. I’ve never used one but some of the tractor backhoes use a PTO driven pump.
/ Adding Remotes to JD950 #7
That PDF JD110 sent is a great resource. After looking at the layout it looks like it could pretty easily be done using aftermarket parts. From what I can see you are just removing plugs and replacing with lines. I'm willing to bet if there is a hydraulic shop in your area they could rig you up with something. I know you could get all the parts likely off surplus center it would be a matter of just getting the right style of fitting.
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
iDrive TDS-2010H...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
