Adding Remotes to JD950
/ Adding Remotes to JD950 #1
Pinch
PA
JD950, Kubota L4610, Kubota B2620
I have a JD950 (Yanmar) without hydraulic remotes, just a 3pt hitch, no loader. What would I need to add two sets of remotes. Here are some images - click on them to enlarge. Thank you
/ Adding Remotes to JD950 #2
I have attached the instructions for installing the john deere kit, which is not available anymore unfortunately. You may be able to find parts used or you could plumb in a valve of your choosing as long as it is for an open center system. If you have a lower serial number than 12000 you have some differences.
  • 950 scv wo power.pdf
/ Adding Remotes to JD950 #3
The only practical way to do this is to buy the complete system off a salvage tractor. Probably easier to just buy a different tractor. What are wanting to do with the remotes? If you are wanting to add a loader you may not be happy without power steering and 4WD.
Thanks for the advice and thanks to jd110 for the instructions. I want to use a specialized side-mounted implement for hilling up and down. My 950 has only ever been used for mowing but it would be perfect because it fits in the rows. Oh Well
The manufacturer thinks it will work on my B2620 Kubota which is a smaller compact, not so much in HP, but in size and weight. I'm worried it's too light for moving soil
/ Adding Remotes to JD950 #6
Would a PTO mounted pump work for this implement? Might be an option for you. I’ve never used one but some of the tractor backhoes use a PTO driven pump.
/ Adding Remotes to JD950 #7
That PDF JD110 sent is a great resource. After looking at the layout it looks like it could pretty easily be done using aftermarket parts. From what I can see you are just removing plugs and replacing with lines. I'm willing to bet if there is a hydraulic shop in your area they could rig you up with something. I know you could get all the parts likely off surplus center it would be a matter of just getting the right style of fitting.
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
