Adding rear weight
/ Adding rear weight #1
Carl Bert
Platinum Member
Rockland county, New York
Kubota B26, John deere X595
My B26 is way too front heavy when I use it without the backhoe. I wanted to know what options I have as to adding rear weight. And would I be able to use these weights along with a rear blade or is the blade heavy enough on its own. Keep in mind that the FEL on the B26 weighs almost 700 lbs. Thanks
/ Adding rear weight #2
Put what ever the loader is rated to lift on the back.
/ Adding rear weight #3
First I would add fluid in the tires. ONLY UNLESS that would put you over trailerable weight with the hoe on. This should add ~ 200lbs per tire.
Then just use a heavy implement. Box-blade or bushhog.
If you shop used implements, you can usually buy them cheaper than you can build a weight box and fill with comcrete. And if you buy an implement, it will have more uses than just dead weight out back. I built a concrete ballast when I got my tractor, but now that I have a various assortment of implements, it is just a hunk of concrete that never gets used.
/ Adding rear weight #4
Just a little reading for you.
Type in rear ballast in the search function and you will get lots of results.
/ Adding rear weight #5
I bought a carryall at TSC and put weight on the back until I have enough. I can use the carryall for other things -like moving firewood or the trash down to the road.
Like LD1 wrote - if you get an implement you will have it for something else besides the weight.
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
GOOSENECK SPOOL TRAILER (A65643)
GOOSENECK SPOOL...
Landhonor Attachment Storage Rack (A66408)
Landhonor...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
