Adding Rear Remotes
/ Adding Rear Remotes #1
Riddler
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
Need to add rear remotes to my Kubota L3130. There is no loader or back hoe on the tractor, and likely never will be.
The two pages of the Operator’s Manual that I have attached below say that I should be able to plug my hoses into the hydro block underneath the right footrest by simply removing the cover. Does anyone here have experience doing this? Seems pretty straightforward. Hence, I am assuming I can attach a monoblock control valve on the fender next to the driver’s seat and run my 3 hydro lines directly to the existing hydro block. Just wanted to
check before I start ordering the necessary parts.
/ Adding Rear Remotes #2
Yes it is straight forward.
Your new control valve needs to be open center and have it’s own pressure relief valve and it needs to have power beyond port with the appropriate sleeve or plug depending on the valve design.
/ Adding Rear Remotes #3
My L3430 was ordered with one rear remote and I added two more for a T&T kit by tapping that hyd. block.
I made a bracket that attaches to the ROPS using existing bolts, no cutting or drilling required. It holds a Prince two spool valve over the right fender:
I added two OEM coupler housings to the stack:
It took around 3 days to fabricate and cost just under $1K
  • Good Post
Reactions: fc1
View attachment 881831 View attachment 881833
Thanks so much for all the detail, especially the photos. Super clean OEM-style look.
Tennant T17 (A64127)
Frontier 6' 3Pt Mower (A66408)
Frontier 6' 3Pt...
Case HI DMI (A62613)
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
Timpte Hopper Bottom (A63689)
Timpte Hopper...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
