Adding rear remotes to 855
/ Adding rear remotes to 855 #1
FreakDaddy
Has anyone added rear remotes to their 655/755/855/955? If so how did you do it? I'm about ready to add them to mine and I plan to use selector valves close to the loader and hoses running to the rear so I can turn on the loader or the remotes but not both at the same time. Not ideal but it seems like the easiet way.
/ Adding rear remotes to 855 #2
Boy, it's been a long time since I've thought about this, but as I recall you could either have SCV's (remotes) to the front for Loader use or to the back (for whatever). Now, you could get an Auxilary Hydraulic kit which would give you unregulated flow straight from the Hydraulic pump (you would need to plumb in a Valve). Other than that, I don't think we had the foresight back then to offer it (someone might correct me here)-
/ Adding rear remotes to 855 #3
There are 2 way to get this done...
The more expensive way is to find a PowerBeyond kit to fit your tractor if they are still available through JD, then you can add a new set of valves(SCV's) and have true rear remotes, independent of the FEL. This option will probably cost $500 to $800.
The cheap way to do it is to go to your local hydraulic shop, and get long hoses and 4 sets of quick disconnects(QD's). You can run the long hoses to the rear, and unplug the loader hoses and plug in the long hoses to get your "rear remotes".
Are you trying to get 1 or 2 remotes?
What are you going to operate in the rear?
/ Adding rear remotes to 855 #4
I have done it for the 955 (3 times). JD no longer makes
the remote valve kit, but you can buy the parts separately.
The only thing you MUST get is the power beyond plug that
goes into the hydraulic block just aft of the loader valve. It
is just a hex plug with a funky thread and costs about $2.50.
You can get your own fittings, hoses, and valve(s). You need
to look at the parts book or look at the diagram on your
dealer's computer.
I'd like two remotes so I can add cylinders to my sprayer booms and operate them independently. I have many things that I would use the remotes for too. Here's my sprayer I built...
Turfgrass sprayer link
/ Adding rear remotes to 855 #9
From one of the photos it looks like your tractor already has the power beyond kit.
I thought I could see the hose loop.
So like the other guy said you could make a little frame/plate, mount a couple of valves and
plug into the existing open center power beyond.
/ Adding rear remotes to 855 #10
</font><font color="blue" class="small">( Is the power beyond plug in one of these pictures?
Link to JD 855 parts diagram )</font>
This looks a little different than my 4110, but I think it is #18, part # PT13744, PLUG .It should screw into the block somewhere between the two hoses that go to the rear. The plug blocks fluid from passing though the block, and forces it to the OUT port, through the valve then back to the IN port. This loop MUST be continuous whenever the tractor is running, as the full rated hydraulic flow will be passing through this line.
/ Adding rear remotes to 855 #11
And here is a LINK to the post I made when I added remotes to my 4110, it ma be of some value to you.
/ Adding rear remotes to 855 #12
For the 955, it is item # 15 in your first picture. The part #
is the same as posted for # 18 in the other picture.
All this set-up gets you is a hyd circuit for use with a
backhoe and/or aux valves. I would buy a 2-spool open
center valve that you can mount on your rt fender. It
will require a low pressure return and a pwr beyond out.
Get one that can handle at least 10gpm to avoid overheating.
Why will this valve require a power beyond out? Wouldn't that only be needed if I planned to connect another valve?
/ Adding rear remotes to 855 #14
</font><font color="blue" class="small">( Why will this valve require a power beyond out? Wouldn't that only be needed if I planned to connect another valve? )</font>
That is correct, no PB needed. However, you may want to get one that you can put a PB sleeve in just in case your needs change in the future.
/ Adding rear remotes to 855 #15
The PB out on your new aux valve is needed if the internal
3pt lift cylinder is downstream of the the loop installed as
described previously. If the 3pt cyl is upstream, then it is
not needed. I do not know if the 3pt is up- or downstream,
so I took the safe way out.
As for when you use a backhoe, I have found that the
3pt lift control is easily moved accidentally (bad), I take off
the handle when the backhoe is on.
dfkrug... I have all the parts now. Can you advise where the diverter plug is supposed to go? Everything is pretty straightforward except the location of that plug.
John Deere Rear Rim 38xWH14L (A64119)
John Deere Rear...
LAWSON AERATOR (A63291)
LAWSON AERATOR...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
John Deere Gator (A64119)
John Deere Gator...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
