Adding rear hydraulics to J2023
   / Adding rear hydraulics to J2023 #1
fhennigan
melder,la
ls j2023h
:confused2: I need to add rear hydraulics to a J2023. I know there's a kit out there, but the ports are taken up by the fel. Is there a way around this? Any help would be appreciated.
   / Adding rear hydraulics to J2023 #2
The kit would tap into the power beyond coming out of the loader valve before it gets to the three point hitch hydraulics.
Theoretically, you could install as many rear remotes as you like, but the first valves in the system always have priority.
The steering always gets first dibs on hydraulic flow, but it doesn’t really rob from the rest of the system. Then the loader valves, then rear remotes, and last is the three point.
Thanks,that helps a lot.
iDrive TDS-2010H...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
