etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,392
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have a Yanmar YM2310. Last year I bought a hydraulic cylinder/valve combo made for adding power steering to this tractor. I got or made all the parts necessary to do the job except for the hose and some fittings. The project got put on hold for a while but now I once again have time to finish it. Before I order the hose and the rest of the fittings I would like some advice on plumbing.
The tractor has an aftermarket FEL and the valve for the FEL has power beyond. The hydraulic line that used to go directly to the 3PH was cut and now goes to the FEL valve. From the power beyond port on the valve a hose goes to the line that goes to the 3PH.
I have a flow divider and from that divider the fluid will flow to the power steering cylinder and to something else. The divider can be plumbed before the FEL valve. If plumbed that way the FEL and 3PH will be affected by the reduced flow. If the divider is plumbed after the FEL valve then only the 3PH will be affected. I think the latter scenario is the best way to plumb everything. I could be wrong though.
To maybe make things more clear I will restate things. The output from the hydraulic pump can go to the divider first. Then from the divider the pressurized fluid will go to the power steering cylinder and the FEL valve. Then from the FEL valve power beyond port the fluid will go to the 3PH. OR, the output from the pump can go to the FEL valve first, then from the power beyond port to the divider. Then fluid from the divider will go to the power steering cylinder and the 3PH.
If I plumb the diverter before the FEL it will mean less fluid to the FEL so it will move slower but the steering will work even if I am using the FEL. If I plumb the divider after the FEL the steering won't work if I am moving the FEL but the FEL will move as fast as it does now.
I can raise the engine RPM to compensate for the decrease in fluid if the divider is plumbed before the FEL. I don't usually use the FEL at top engine RPM anyway. Another way to compensate for reduced flow would be to buy and install a hydraulic pump with a larger displacement. However, I have not been able to find one that will fit my tractor.
Opinions?
Thanks,
Eric
Opinions?
Thanks,
Eric
