Adding power steering & power beyond plumbing question
/ Adding power steering & power beyond plumbing question #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have a Yanmar YM2310. Last year I bought a hydraulic cylinder/valve combo made for adding power steering to this tractor. I got or made all the parts necessary to do the job except for the hose and some fittings. The project got put on hold for a while but now I once again have time to finish it. Before I order the hose and the rest of the fittings I would like some advice on plumbing.
The tractor has an aftermarket FEL and the valve for the FEL has power beyond. The hydraulic line that used to go directly to the 3PH was cut and now goes to the FEL valve. From the power beyond port on the valve a hose goes to the line that goes to the 3PH.
I have a flow divider and from that divider the fluid will flow to the power steering cylinder and to something else. The divider can be plumbed before the FEL valve. If plumbed that way the FEL and 3PH will be affected by the reduced flow. If the divider is plumbed after the FEL valve then only the 3PH will be affected. I think the latter scenario is the best way to plumb everything. I could be wrong though.
To maybe make things more clear I will restate things. The output from the hydraulic pump can go to the divider first. Then from the divider the pressurized fluid will go to the power steering cylinder and the FEL valve. Then from the FEL valve power beyond port the fluid will go to the 3PH. OR, the output from the pump can go to the FEL valve first, then from the power beyond port to the divider. Then fluid from the divider will go to the power steering cylinder and the 3PH.
If I plumb the diverter before the FEL it will mean less fluid to the FEL so it will move slower but the steering will work even if I am using the FEL. If I plumb the divider after the FEL the steering won't work if I am moving the FEL but the FEL will move as fast as it does now.
I can raise the engine RPM to compensate for the decrease in fluid if the divider is plumbed before the FEL. I don't usually use the FEL at top engine RPM anyway. Another way to compensate for reduced flow would be to buy and install a hydraulic pump with a larger displacement. However, I have not been able to find one that will fit my tractor.
Opinions?
Thanks,
Eric
/ Adding power steering & power beyond plumbing question #2
I would install the priority flow divider between the pump and FEL valve. Your steering should have hydraulic priority over anything else. The sacrifice in FEL speed is minor compared to loss of steering when you inadvertently activate the FEL while moving and steering. And it will happen.
/ Adding power steering & power beyond plumbing question #3
You must have the system relief as the first valve in the pressure line. I agree steering should have priority so you may need to add a relief to the system before the the flow control.
You are correct. I do need to have the steering at all times, it does need to have priority. I will plumb the divider before the FEL valve.
Thanks,
Eric
/ Adding power steering & power beyond plumbing question #5
Our machine has a power beyond port on the steering valve. That feeds the FEL, then returns to tank. That makes the steering have priority.
I didn't consider that a pressure relief valve might be needed. There appears to be two already on my tractor, one somewhere in the 3PH hydraulic system and one in the FEL valve. Since the divider splits flow at all times even if the power steering cylinder is dead headed won't the two other relief valves still do their job? I don't see how the pressure could get too high if the divider is always venting fluid to the FEL and the 3PH. Now I am wondering how the divider works. It must capable of be delivering high pressure fluid to the power steering cylinder valve even if the other port dumping directly into the hydraulic fluid sump. So it must already have some sort of pressure relief inside.
Thanks,
Eric
/ Adding power steering & power beyond plumbing question #7
Most priority flow controls block all excess or bypass flow if priority flow is blocked so if something blocks flow in steering circuit what happens? Hose break, steering unit crack, pump housing crack? Not trying to scare just provide some insight on how the valves work.
/ Adding power steering & power beyond plumbing question #8
Check your tractor for the relief location. Many have a relief at the pump. If it does, then you don’t need to add a relief. If it located somewhere else on the tractor, then you need a relief between the pump and flow divider.
I guess I don't understand how a flow divider works. I thought that inside the diverted is a pressure relief valve that is constantly operating. The relief valve keeps the regulated flow at high pressure and dumps any high pressure fluid not needed out of the port that goes to the FEL or 3PH or whatever or the sump. It sounds like you are saying that if the regulated flow is dead headed then all flow from the divider stops, both ports will have no flow. Am I wrong?
Eric
/ Adding power steering & power beyond plumbing question #10
A flow divider and priority flow control are two totally different valves and operate in a different manner.
Priority flow control directs a predetermined flow to the controlled flow port and all excess flow is directed to the excess flow port. This is most common valve used for steering since it provides a constant priority flow rate to steering.
A flow divider splits the flow at some predetermined ratio. This ratio does not change so with 4 GPM inlet and 50:50 split you get 2 GPM to each circuit. With 6 GPM inlet you get 3 to each circuit. With most flow dividers blocking flow in one leg blocks flow to both legs. Most common use is trying to keep two circuits operating at the same speed.
I don't know which type I have but I suspect it is the priority type. I guess I can check by blocking the regulated port. Since only one port is marked regulated I must have the priority type. I see devices like mine except they are adjustable from outfits like Summit and they call them dividers. Would they block flow from both ports if one port was blocked?
Thanks,
Eric
/ Adding power steering & power beyond plumbing question #12
If marked regulated I would also suspect priority flow control. Yes it gets confusing on what type if valve you have when names are interchanged.
Thanks. It is confusing when names are interchanged. I'm pretty sure I don't need another relief. I guess I can check by turning the steering wheel full stop and see if fluid still comes out of the other port.
Eric
/ Adding power steering & power beyond plumbing question #14
Be careful since if no flow movement and no relief the weakest link will break.
If you have style of priority flow control with built in relief the relief vents to the excess flow. Any pressure in the excess flow port is additive to relief setting.
Example: relief set at 2000 PSI and load on excess flow is 1000 PSI. Do some thing that block priority flow and relief will open at 3,000 PSI.
I don't know how to tell without testing. The guy I bought the valve from has not answered my emails. Can I test the divider just by using turning the steering wheel a little? Would the fluid stop flowing from the non regulated port on the divider as soon as the regulated port starts to deliver fluid under pressure?
Eric
/ Adding power steering & power beyond plumbing question #16
Do you have any information on the valve you have like make, model number, any published info with schematic?
I am basing my concern on working for a valve manufacturer years ago and typical operation for vast majority of priority flow controls at that time was as I have described.
/ Adding power steering & power beyond plumbing question #17
If you don’t know if your tractor has a relief at the pump and you don’t know if you have a relief in your priority valve, then you need to add a relief valve! It needs to be between the pump and priority valve inlet. It needs to be set above your FEL, steering, and 3PH relief. I would be at 150 - 200 PSI above your highest setting to avoid chattering of the reliefs.
I ordered a 16 GPM priority valve with relief. It was the lowest flow one I could find. Please don't tell me you found an 11 GPM valve unless you are gonna supply it to me at no cost. When it arrives I will find out if the mounting plate I made for the other valve will work. Once that's done I can order fittings and hose. I decided to order a pressure gauge too. They are inexpensive and it will let me know if the pressure is getting too high, hopefully before I damage something.
I also found a larger displacement pump so if stuff is too slow I have that option. Even though it's a 400 dollar option. And speaking of pumps, my son and I looked at my tractor to see once again how much trouble it would be to use a car power steering pump. I was given a Honda Civic pump, at least I think that's the car it came from, and it fortunately spins in the opposite direction of most pumps. This means it can be mounted with its face facing the crankshaft pulley face. If I did this without changing anything on the tractor the power steering pump would need to be shaft driven and sit out in front of the tractor cowling. This would be problematic because of the FEL mount. Among other things.
On my tractor is a cast weight that the battery sits on and it has clearance for a shaft that could drive a pump. But I could instead remove the weight completely and make an new battery mount that elevates the battery a couple inches. This would give me enough room to mount the power steering pump below the battery. I would lose the extra weight but my tractor has an aftermarket FEL mounted and it surely weighs more than the stock cast weight under the battery. And I can still mount that weight somewhere else out in front of the cowling anyway.
Before I go too far though I am gonna grab the power steering pump in the lathe chuck and spin it at 900 RPM to see just how much fluid it pumps per minute so I can compare it to the hydraulic pump in my tractor. To make the test as accurate as possible I will put in a flow restrictor so the pressure can be raised to 1500 PSI. This will not only test pump output it will also test the pump to see if it is a good pump and if the rotation direction is right. The guy who gave it to me thinks it is a good pump and thinks it spins in the direction I need.
Anyway, I'm excited to get the new valve so I can order the hose and fittings and get the job done. I have fabbed everything needed so far and if the new valve will work with the mounting plate I made that means the only thing I will need to do is plumbing. HAH!
Eric
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 FREIGHTLINER...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
