Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
This week I used the new setup a bit, and decided the levers were a bit too close to my elbow. So I changed the angle of the levers of the aux control valve, by adding a quarter-inch of length to the three small linkage bars (visible in the first couple photos in this thread, they are the 1/4" x 3/4" flat bar parts of the forward control setup). Making the replacement linkage bars longer layed the three levers down forward at a lower angle. The handles actually dropped 1.5 inches or so. No more elbow-room interference, and the drink holder is still useable.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #42
Awesome thread!
And an awesome job!
It turned out very professionally!!
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #43
This is an awesome thread, my question is, would this be the same on a 4500 JD? and did you get the parts from a tractor supply or a hyd. supplier? Thanks
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #44
Indeed a good job. This may get my vote as Thread of the Year.......
I captured this thread in a PowerPoint presentation (pics and all) and a PDF file for future reference. This setup has to be a good general guideline for most any color of machine.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #45
Great job Jim,
Wish I had your fabrication skills, I'll be in the shop all the time. I don't believe the 2520 offers any additional hydraulic options other than a hydraulic coupler kit that does nothing more than route the dual SCV's ports to the rear of the tractor.
Question: Are the quick connect couplers you installed compatible with the factory ones? What part number are they? Thanks.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #46
Hi CBR, Since you've already done the hard part, can you share your presentation so us lazy foks don't have to? :p
MikeDeere, suppliers of stuff:
John Deere dealer sold me the setscrew, and a replacement Oring when I pinchedone upon reassembly.
Surplus Center (.com) sold me all the hose, most all the fittings, the Prince sectional valve.
Local distributor called Ronco sold me the couplers and coupler nipples and a couple fittings I couldnt find on surpluscenter.com.
I fabricated all the steel bracketry.
Superduper, couplers and nipples: They came from Ronco (local guys), and were Pioneer 4050 p2 and 4010 p2. Yes, they are the type used on the tractor originally.
CRBR, I agree, it would be nice to have the thread captured, if you are sending them out I would gladly take a copy too!
Thanks guys!
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #48
jimgerken, Do you know if this will work on a 4500 series??
No I don't know much about the 4500 series, but a guy who works with me is about ready to buy one, so eventually I may be able to get a look at his and make a guess. I warned him to get the Power Beyond kit installed by the dealer to avoid some hassle. However, I would guess there is a way to get it done without the expense of the PB kit. I am assuming you don't have Power Beyond or any JD-installed auxillary hydraulics, correct? Cause if you happen to have either of those already, you have the hydraulic flow already available for your use in an additional valve.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #50
jimgerken, do you think a person could add one valve to a 2305 tractor? there isn't a removeable piece behind the loader valve, but there are 2 plugged openings in the casting, and a third at 90degrees, like the one you put the allen plug in. I would like to add a valve myself.
thanks for any info, bmw
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #51
Jimgerkin, I do have the third SCV but I don`t think I can get it from there. Maybe I am wrong. Doe`s any body know? Thanks
bmw, I don't know, you'd have to dig into it. Find the installation instructions on the Power Beyond kit for your tractor, either on-line thru JD parts, or through your dealer if he is willing. This will give the hints to get you started. Sorry I cannot be more help.
New photos are here. These show the final (unless I change it again) routing of the TnT hoses. And the last pic is a bonus, showing the result of several hours of machining effort on some wheel weights I was given.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #54
Mikedeere, with the 3rd SCV, the simplest solution is to install an electric diverter valve from the 3rd SCV outlets which will split it into A & B accessory ports. The original 3rd SCV lever will still operate your accessories. However, you select the port being controlled by activating an electrical remote mounted switch which I've even seen other users install as a pushbutton on the 3rd SCV lever. The valve which most folks seem to use is this one by surplus center: Surplus Center Item Detail
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #55
Thanks Superduper, I`ll look into doing that. :
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #56
Jimgerkin, What a fantastic job! Since I am hydraulically challenged I have been only wishing I could figure out how to do this my JD 4600 for a long time. Currently I have the powerbeyond lines installed. I believe I can run the 3 spool valve supply and return lines from it. But because of the location of the PB quick disconnect fittings I'm afraid there would be way too much clutter in the area and I would not be able to fold the ROPS completely down. I would like to supply the valve from elsewhere as you have. Hopefully this is possible. Do you know if there is a similar block to tap on my machine? THe dealer hasn't been able to answer this question. I read earlier in this thread where someone had inquired if the same could be done on a 4500 model. I believe our tractors are basically the same. I wish you where my neighbor.
jrschremser, if you have the power beyond option installed, the flow is in there! P.B. has two hoses, right? And they come up to a mounting plate and fittings on the rops base or fender, I assume. And there is a small loop hose that must always be installed in there to keep the flow going through, or the releif valve must open and eventually your system would overheat (This info came from the owners manual). Your new valve goes in that loop, in place of the small loop hose presently connecting the two hoses coming up from the hydraulics block area. You have it made, the hard part has been done for you. Choose an open center valve of at least 3000psi working and at least the gallons per minute (gpm) flow rating of your system. You will have to figure out which of the P.B. hoses is "supply" and which is "return". Mount the valve, add couplers and you are there. If any of these assumptions of your present setup sounds wrong, please post pics of what you have so we can understand and help more.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #58
I like the zip tie marking. Very clever. Also more practical than the electricians tape I was trying to use last week.
To follow up and answer a question I have been asked a few times now, and just often enough so I forget between times, here is an update. The hydraulic block on your tractor has two ports, as you've seen in my earlier photos. When the block is mounted on the tractor, with the setscrew in place inside the block, and you are ready to plumb out to your aux valve:
The hydraulic supply from the tractor comes out of the rear-most port on the hydraulic block. This should be routed to the port of your auxillary valve called "in".
The return to the tractor hydraulics is the front port on the block. So, the flow from your auxillary valve, out of its "out" or "return" port, gets routed to the front port on the hydraulic block.
Doing this puts your new auxillary valve in series with all the other tractor hydraulics.
Good luck, and watch those "o"rings !
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #60
jimgerken, I just recently ordered a 2520, am planning on adding valves like you did, copying your idea of making your own power beyond!! Should save me a ton( i think they get around $300 for the kit!! I am wondering what size hydraulic lines you ran from the block to the add-on valve, it looks like 3/8 in your pics but was just wondering if that was big enough, since it always has flow through it. i know the ports are #6 which is not real large just wondering your thoughts on this, since i haven't actually looked at my tractor yet!!
will post more on that later, and pics of the new valve installed as well!
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
Booster Cables (A59230)
Booster Cables...
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
