Adding MF 232 loader using MF231 tractor hydraulics
/ Adding MF 232 loader using MF231 tractor hydraulics #1
ptbsn8
MF231
Hello, I hqave a MF231. I recently purchased MF 232 loader and am trying to tap into the internal hydraulics to power the loader. I purchased a hydraulic selector valve but it doesn't have a return port back to the selector valve form the loader control valve. The 3 ports shown only supply 3 options for pressure as far as i can tell. Can anyone help me with a place on the tractor hydraulics case or transmission that i can hook my loader control valve for the hydraulic return? Or is ther a better diverter valve i should be using? This vale replaces 180908M1 INTERFACE COVER PLATE WHICH IS LOCATED ON THE HYDRAULIC LIFT COVER. Thank you for any help!
/ Adding MF 232 loader using MF231 tractor hydraulics #2
Did you ever get this figured out. I have a 240 with the valve and the pump seems good but the valve does not send flow to the MF232 loader.
/ Adding MF 232 loader using MF231 tractor hydraulics #3
Is the draft lever all the way up and position control lever in constant pumping? That's how you fool the pump to supply externals.
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
46177SFL (A64557)
46177SFL (A64557)
