Adding MF 232 loader using MF231 tractor hydraulics
/ Adding MF 232 loader using MF231 tractor hydraulics #1
ptbsn8
MF231
Hello, I hqave a MF231. I recently purchased MF 232 loader and am trying to tap into the internal hydraulics to power the loader. I purchased a hydraulic selector valve but it doesn't have a return port back to the selector valve form the loader control valve. The 3 ports shown only supply 3 options for pressure as far as i can tell. Can anyone help me with a place on the tractor hydraulics case or transmission that i can hook my loader control valve for the hydraulic return? Or is ther a better diverter valve i should be using? This vale replaces 180908M1 INTERFACE COVER PLATE WHICH IS LOCATED ON THE HYDRAULIC LIFT COVER. Thank you for any help!
/ Adding MF 232 loader using MF231 tractor hydraulics #2
Did you ever get this figured out. I have a 240 with the valve and the pump seems good but the valve does not send flow to the MF232 loader.
/ Adding MF 232 loader using MF231 tractor hydraulics #3
Is the draft lever all the way up and position control lever in constant pumping? That's how you fool the pump to supply externals.
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
(75) Square Grass Hay Bales (A66408)
(75) Square Grass...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
