Adding light switch to NX
/ Adding light switch to NX #1
justman777
Platinum Member
San Antonio, TX
Kioti NX4510 Cab
Want to add a switch on the right column of my NX by removing one of the blanks where all the other light switches are. I ordered a standard rocker switch off Amazon, but it's sloppy in the fitting. Does anyone know of a switch that'll fit that I don't have to pay a dealer $50 for? For clarification, I want to add the switch to the right column where all the other light switches are. On the NX cab model, this is right above the PTO switch/knob.
If I can't find a reasonably priced switch that'll fit, my plan is to make do with some hot glue to the back side. Any other ideas?
Thanks!
/ Adding light switch to NX #2
Take some careful measurements of an existing switch which fits. Surf eBay for one with that configuration and those dimensions. That's how I found a replacement rocker switch for my welder.
/ Adding light switch to NX #3
I made a standard Carling switch work but I shimmed it with part of the blank you pulled out.
Thanks!
I wound up resorting to hot glue. Seems to be holding just fine! Used it for some LEDs on the sides.
6 Row Corn Plow (A64127)
6 Row Corn Plow...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
213130 (A64276)
213130 (A64276)
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
