Adding joystick to 3930 loader?
/ Adding joystick to 3930 loader? #21
I'd definitely rather not spend 1200$. I appreciate everyone's help here, as I know only basic stuff about hydrualics. So with the joystick fed from one remote the remote lever would need to be held open for the joystick to get fluid correct? That's how my 3610 is. Would this setup give me less flow to the loader than what I currently have with both remotes?
If the joystick valve is sized for 20GPM the flow would be the same as now.
With the splitter valves like in the other thread could I just keep my remote levers for loader control but still have selectable levers or switches to divert fluid to additional hookups in the rear? I guess that would require lots of hoses though?
Not lots of hoses. A the most, 4 short ones going from your remotes to two splitters. Or you could buy one splitter that had 3 pairs of outlets and get all your available rear remotes from one existing remote and leave the other status quo.
Thanks. Rickb either of those options would be nice. Guess I need to give it some thought as to which way I should go.
/ Adding joystick to 3930 loader? #23
It's been a while, but did you ever get you're situation straightened out?
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2015 Ford F-150 Ext. Cab Pickup Truck (A59230)
2015 Ford F-150...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
