Adding joystick to 3930 loader?
/ Adding joystick to 3930 loader? #21
I'd definitely rather not spend 1200$. I appreciate everyone's help here, as I know only basic stuff about hydrualics. So with the joystick fed from one remote the remote lever would need to be held open for the joystick to get fluid correct? That's how my 3610 is. Would this setup give me less flow to the loader than what I currently have with both remotes?
If the joystick valve is sized for 20GPM the flow would be the same as now.
With the splitter valves like in the other thread could I just keep my remote levers for loader control but still have selectable levers or switches to divert fluid to additional hookups in the rear? I guess that would require lots of hoses though?
Not lots of hoses. A the most, 4 short ones going from your remotes to two splitters. Or you could buy one splitter that had 3 pairs of outlets and get all your available rear remotes from one existing remote and leave the other status quo.
Thanks. Rickb either of those options would be nice. Guess I need to give it some thought as to which way I should go.
/ Adding joystick to 3930 loader? #23
It's been a while, but did you ever get you're situation straightened out?
2025 Ripper Mini Excavator Attachment (A66734)
2025 Ripper Mini...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2019 Ford F-150 Ext. Cab Pickup Truck (A66736)
2019 Ford F-150...
Unused HLA BRB84 84in. Hydraulic Rotary Pick-UP Broom Skid Steer Attachment (A66734)
Unused HLA BRB84...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
