Adding joystick to 3930 loader?
/ Adding joystick to 3930 loader? #1
dntfxr
Platinum Member
north Louisiana
Ford, LS
Hi folks, I'm considering adding a joystick control to my Ford 3930 which is currently controlled with the rear remotes. I'm actually used to using the remote levers but I'd like to free them up for other uses. What all would be involved with adding a joystick and roughly what would it cost? Thanks for any advice and info.
/ Adding joystick to 3930 loader? #2
Here is a joystick valve that will work for you.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Hydraulics:
Type: open center
closed center (optional)
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 2 (open center)
1 to 4 (closed center)
Pump flow: 7.7 gpm [29.1 lpm]
12.8 gpm [48.4 lpm] (optional)
Steering flow: 3.6 gpm [13.6 lpm]
Hydraulics:
Type: open center
Good deal, that's not too bad on price. Thanks for the link.
Does anyone know the best way to plumb it in on this tractor?
/ Adding joystick to 3930 loader? #4
Is your tractor closed or open center? That will be a determining factor on which way to attach valve & what type valve required.
/ Adding joystick to 3930 loader? #5
His tractor data is posted above.
But the again, we don't know if he has the optional closed center system.
Sorry guys I'm not sure if it has open or closed. The tractor information card under the hood has a number for hydraulic pump, and another number for hydraulic lift. Does that mean 2 pumps ? How can I tell for sure?
It's a fwd with the synchro shuttle transmission if that makes a difference?
/ Adding joystick to 3930 loader? #7
But the again, we son't know if he has the optional closed center system.
That's the reason I asked OP if he knew what type hyd's his tractor had. I know some Ford tractors have CCLS hyd systems
I just snapped a couple pics, not sure if this shows what type I have though.
Let's see if this works..
/ Adding joystick to 3930 loader? #9
I think your breakaways are CCLS. If I'm correct to bypass breakaways and plumb JS valve directly to hyd's you'll need a CCLS JS valve.
/ Adding joystick to 3930 loader? #10
Just put a hyd gage in a tee in the IN port of the first valve and if there is pressure at all times, it is closed center.
Open center hyd system will have no or very little pressure on the gage..
2003 Honda Accord Sedan (A59231)
2003 Honda Accord...
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
