Adding insult, and more injury......and a bit irony..............
   / Adding insult, and more injury......and a bit irony.............. #22
So one owns a tractor but can't figure out how to remove 4 bolts to swap the mower gearbox? Doesn't take that much effort.
Plenty of people on this site that are that way, why do you think they came here? To learn!
   / Adding insult, and more injury......and a bit irony.............. #24
Folks come to TBN for help, not to be put down because they do something different than you would.
This is true.
And it's worth knowing too, for those questioning the decision, that the unit is very old, has weld cracks in the supports and in the stump jumper and as it is over 90 inches wide has always been difficult to maneuver around trees in the planted stands. Because of this we forewent some internal mowing of stands needing burning and hardwood control on, something that a heavier duty and narrower cutter will allow.
I should also mention that hitting the base of a pine while mowing will often allow beetles in which will kill that tree, trees which are OUR CROP.
Spending heaven knows how much......and the time to do it that could be spent on other productive behavior ( got some culverts that need cleaning out ).......and ending up with a unit that is still old and still marginal for what we were doing with it did not make sense.
I do appreciate the constructive suggestions I usually receive here when asking questions.
   / Adding insult, and more injury......and a bit irony.............. #26
Some people really do have a very narrow field of vision and find it impossible to consider anything different from how they see or operate in this reality.
Like saying, I think someone would be oh so foolish to discard some broken electronic device, rather than perform circuit level repair. Helll, it's probably just a .39 cent SMT chip!
   / Adding insult, and more injury......and a bit irony.............. #27
Or this:
   / Adding insult, and more injury......and a bit irony.............. #28
If intent was to replace it all along, why was the subject even brought up?.. Its always funny how more precise information about problem and desire on how to fix always changes as more opinions are forth coming, always making previous message and solution seem counter productive and narrow minded.......
Dale
Dale
The insight given was what tipped the scale. As I know I do not know everything I need to know, it helps to get ideas and insight from others' experience.
   / Adding insult, and more injury......and a bit irony.............. #30
By any chance, had you heated the end of the shaft to remove the nut & jumper? If so, you may have case hardened the shaft and it became brittle.
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
New/Unused Quick Attach Rock Breaker (A54865)
New/Unused Quick...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
