Adding hydraulics to a sickle bar mower
   / Adding hydraulics to a sickle bar mower #11
Pic.#2
   / Adding hydraulics to a sickle bar mower #12
Pic.#3
   / Adding hydraulics to a sickle bar mower #13
Last one #4. If you do this this I would advise using flow restricters on both sides of the cylinder.I used 1/16 flow restricters on my IH1300 after I found that under normal operating pressure the cutter goes up and down extremly fast. I really like this setup, On my IH1300 you can control the cutter to cut horizontal or vertical or anywhere in between. This makes it nice for cutting back brush up to 1" diameter on trails or along roads. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Bernie
   / Adding hydraulics to a sickle bar mower #14
Thanks Bernie…
I was thinking of something along that line … I may have to make some type of ‘cam-over’ arrangement to allow a steep negative angle, as along a ditch. What cylinder length is that? KennyV.
Excellent work Bernie. It looks like where your cylinder is mounted that would take the place of the spring on the New Holland. How long of a cylinder is that? Here is some pictures of the mower. Paint job is badly needed.
Pic 2 oops same picture /forums/images/graemlins/grin.gif
Next one
another
   / Adding hydraulics to a sickle bar mower #19
This cylinder is 2" with a 16" stroke. It took the place of a 5/8 curved rod. I had to measure with the cutter up and down then figure what cylinder to use.
Bernie
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
1999-2010 Ford Pickup Truck Bed (A49461)
1999-2010 Ford...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
