Adding hydraulics to a sickle bar mower
   / Adding hydraulics to a sickle bar mower #11
Pic.#2
   / Adding hydraulics to a sickle bar mower #12
Pic.#3
   / Adding hydraulics to a sickle bar mower #13
Last one #4. If you do this this I would advise using flow restricters on both sides of the cylinder.I used 1/16 flow restricters on my IH1300 after I found that under normal operating pressure the cutter goes up and down extremly fast. I really like this setup, On my IH1300 you can control the cutter to cut horizontal or vertical or anywhere in between. This makes it nice for cutting back brush up to 1" diameter on trails or along roads. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Bernie
   / Adding hydraulics to a sickle bar mower #14
Thanks Bernie…
I was thinking of something along that line … I may have to make some type of ‘cam-over’ arrangement to allow a steep negative angle, as along a ditch. What cylinder length is that? KennyV.
Excellent work Bernie. It looks like where your cylinder is mounted that would take the place of the spring on the New Holland. How long of a cylinder is that? Here is some pictures of the mower. Paint job is badly needed.
Pic 2 oops same picture /forums/images/graemlins/grin.gif
Next one
another
   / Adding hydraulics to a sickle bar mower #19
This cylinder is 2" with a 16" stroke. It took the place of a 5/8 curved rod. I had to measure with the cutter up and down then figure what cylinder to use.
Bernie
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
