Adding hydraulics to a sickle bar mower
   / Adding hydraulics to a sickle bar mower #11
Pic.#2
   / Adding hydraulics to a sickle bar mower #12
Pic.#3
   / Adding hydraulics to a sickle bar mower #13
Last one #4. If you do this this I would advise using flow restricters on both sides of the cylinder.I used 1/16 flow restricters on my IH1300 after I found that under normal operating pressure the cutter goes up and down extremly fast. I really like this setup, On my IH1300 you can control the cutter to cut horizontal or vertical or anywhere in between. This makes it nice for cutting back brush up to 1" diameter on trails or along roads. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Bernie
   / Adding hydraulics to a sickle bar mower #14
Thanks Bernie…
I was thinking of something along that line … I may have to make some type of ‘cam-over’ arrangement to allow a steep negative angle, as along a ditch. What cylinder length is that? KennyV.
Excellent work Bernie. It looks like where your cylinder is mounted that would take the place of the spring on the New Holland. How long of a cylinder is that? Here is some pictures of the mower. Paint job is badly needed.
Pic 2 oops same picture /forums/images/graemlins/grin.gif
Next one
another
   / Adding hydraulics to a sickle bar mower #19
This cylinder is 2" with a 16" stroke. It took the place of a 5/8 curved rod. I had to measure with the cutter up and down then figure what cylinder to use.
Bernie
Pallet Fees (A50774)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
