IF I HAD REAR HYD, I WOULD RUN A LINE TO THE FRONT TO POWER A GRAPPLE. I COULD ALSO USE FOR REAR TP CYLINDERS. THE THREAD I SAW A WHILE BACK SAID VALVES COULD ATTACH ALONG SIDE THE FEL CONTROL AND FEED THEM FROM THE FEL CONTROL VALVE, THEN RUN HYD HOSES TO BACK QUICK CONNECTS. I GUESS I'M TRYING TO ELIMINATE AS MUCH PLUMBING AS POSSIBLE. REFERENCE WAS MADE OF A COMPANY THAT SELLS VALVES AND HARDWARE TO CONNECT IN THAT MANNER. I THINK SOLAR WHOLESALE WAS MENTIONED, BUT I CAN'T ACCESS THEM. THANKS FOR YOUR TIME.
