Adding external 3PH control for 2555 shuttle? cab
/ Adding external 3PH control for 2555 shuttle? cab #1
OzarkChris
Calamine AR
Mahindra 2555 Shuttle Cab
I'm hoping I can add/fabricate a simple external control for the 3PH. I was told when I purchased this tractor (a barely used 2019 - 45 hr) about 6 months ago that the factory has a package that goes by the rear lights, but that appears to need some major changes - solenoids etc. So I'm guessing it would be quite $$$. Looking at the current mechanism it looks like I should be able to just add a handle to the external linkage but wanted some advise before I do something I shouldn't do. I would also like to do remotes from back there as well - for hydraulic toplink.
Any suggestions would be greatly appreciated!
/ Adding external 3PH control for 2555 shuttle? cab #2
I was wondering the same thing on my 2645. There are places (cutouts) by the rear lights which could accommodate momentary switches for such a function. It would require significant changes due to the fact the current control valve is manual rather than solenoid controlled. An extension welded to the current manual control may suffice however future servicing could be impacted significantly.
2025 Swict 72in Bucket Skid Steer Attachment (A66734)
2025 Swict 72in...
PORTA POTTY (A67714)
121A (A63745)
121A (A63745)
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
Set of 2 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 2 Unused...
2009 TRAIL KING (A67714)
2009 TRAIL KING...
