Adding air to a loaded tire
   / Adding air to a loaded tire #11
Try giving your tractor a bump of air then check it.
   / Adding air to a loaded tire #12
does air come out when you press the Schrader valve down?? :)
as Murph said, shoot some air into the stem first to clear it.. especially if it is a liquid filled tire.
If it is an air only tire, and a very light tractor, sometimes just tire sidewall will hold a rim up and the tire may be 'deflated'.
post back.
   / Adding air to a loaded tire #13
What Soundguy said.. My rear tires only have 16 psi in them at most (L3400 Kubota), some automotive gauges will barely read that low a pressure. It's also possible that the stem is clogged with salt crystals if you have calcium chloride. In any case, you may want a spare valve stem handy before you fiddle with it much, I've had a couple go to pieces once disturbed.
   / Adding air to a loaded tire #14
jack the tyre and rotate to the 1/11 oclock position and remove the valve and let excess drain so the tyre is not over filled. Replace the valve and reinflate. NB The reason the fluid should not be higher is because tire gauges won't read liquid AND liquid in tyre gauges is BAD news.
   / Adding air to a loaded tire #15
They make and sell a tire pressure Guage for checking filled tires. They are available at napa.
   / Adding air to a loaded tire #16
Ditto that, a box of spare cores, and one of those 4 way core tools that removes, rethreads and shaves seat is a must on filled tires, as you say, sometimes just checking them makes a leak that needs a new core, or if a 2 part stem, a new end section
   / Adding air to a loaded tire #17
   / Adding air to a loaded tire #18
there is no trick to it. It sounds like the calcium has eaten up the inside of your core housing. They make stainless steel core housings and stainless valve cores to be used with calcium. They make 2 different styles of core housings, old and new style. Your tractors age it could have either 1. The core housing should unscrew from the tube, sometimes it is difficult to do, a new one should screw back in its place. Make sure the valve core you get does not have the long spring sticking inside the core housing. Any established Farm tire repair shop dealing in tractor rears will have the parts you need.
   / Adding air to a loaded tire #19
Can I add air to a tire with calcium chloride in it
   / Adding air to a loaded tire #20
I had a stupid tre like that for years. Thought about changing to beet juice and all that. But I just had a tube put in recently and everything is nice and dry. Should have done that ten years ago.
Even with the liquid gauges, try and wash them as best as you can after use.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
8 TOOTHED BUCKET...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
17307 (A55853)
17307 (A55853)
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
