Adding a storm shelter
   / Adding a storm shelter #21
Better yet….. i live in an area without earthquakes or tornadoes
   / Adding a storm shelter #22
I tend to get claustrophobic in small spaces. I don't think I'd be able to enter that shelter. Seeing a large tornado approaching might just change all that...........
Like grsthegreat - I'm in the same area as he is. No earthquakes nor tornadoes
   / Adding a storm shelter #23
It's like the tenderfoot who asked his guide what he should do if a bear shows up. The guide said "climb a tree".
The tenderfoot said, "What if the tree isn't easy to climb?" The guide said "Don't worry, if a bear is chasing you, you will be able to climb it'
The tenderfoot said "What do I do if the bear starts climbing up after me?
The guide said "Throw poop at it"
The tenderfoot said "what if there is no poop nearby?
The guide said "don't worry, it'll be there"
   / Adding a storm shelter #24
A tederfoot is going on a fishing trip. He shows his guide a 44 mag pistol.
The guide says "what is that for?"
The tenderfoot says "In case we encounter a bear"
The guide says "Did you file off the front sight?"
The tender foot says "Why, is that for night shooting?"
The guide says "No, that's so it won't hurt so much when the bear shoves it up your rear"
   / Adding a storm shelter #25
Or when a griz approaches and one guy says to the other I hope we can outrun the bear... and the other guy says no not really, I just need to outrun you.
   / Adding a storm shelter #26
I put this together for a customer a while back. It eats up garage space but I like the design a lot better than the below ground ones. It’s also capable of being taken apart from the inside if debris are blocking the door.
   / Adding a storm shelter #27
   / Adding a storm shelter #28
   / Adding a storm shelter #29
   / Adding a storm shelter #30
I am thinking if you were stuck inside you could pop one of the vents and shoot a flare or stick a bicycle flag out and wave it.
On the sump pump, I realize sheltering from a tornado is a reletively short time. But, depending on your water table do you think a manual pump would be worth considering?
Doug in SW IA
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2016 Ford F-150...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2018 John Deere 460E Articulated Dump Truck (A55302)
2018 John Deere...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A55787)
2025 60 Gallon...
