Adding a second valve
/ Adding a second valve #1
blitka
I want to add a second single spool valve, my question is how do I plumb it in? do I run the return fron the first valve into the supply for the second valve?
/ Adding a second valve #2
Sort of..... your first valve have to allow PB, power beyond, by having a PB port plus a extra OUT-let port. Also need a PB "plug", in the PB port.
/ Adding a second valve #3
Welcome to TBN:D
We need a lot more info to help you...
/ Adding a second valve #4
blitka, what tractor are you planning to add the single spool on? Have you stopped at a local hydraulic shop to get info ? I stopped at one in the city and they were helpful, I picked up a prince valve for my rear remotes, and still working on getting the rest of parts before starting the project.
Sorry for the lack of info, and thaks for the welcomes. I have been wathing this site for a while, fianallly joined. I have a cub cadet 1650 with hydraulic lift and wanted to add a second valve to add power angle on my plow. Some came with a 2 valve system with front ports, which is what I would like to do. I have a extra single valve and was wondering if I could use this or if I need a new valve. Thanks.
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
3146 (A63117)
3146 (A63117)
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
2005 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2005 INTERNATIONAL...
PORTA POTTY (A68842)
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
