Adding a second valve
/ Adding a second valve #1
blitka
I want to add a second single spool valve, my question is how do I plumb it in? do I run the return fron the first valve into the supply for the second valve?
/ Adding a second valve #2
Sort of..... your first valve have to allow PB, power beyond, by having a PB port plus a extra OUT-let port. Also need a PB "plug", in the PB port.
/ Adding a second valve #3
Welcome to TBN:D
We need a lot more info to help you...
/ Adding a second valve #4
blitka, what tractor are you planning to add the single spool on? Have you stopped at a local hydraulic shop to get info ? I stopped at one in the city and they were helpful, I picked up a prince valve for my rear remotes, and still working on getting the rest of parts before starting the project.
Sorry for the lack of info, and thaks for the welcomes. I have been wathing this site for a while, fianallly joined. I have a cub cadet 1650 with hydraulic lift and wanted to add a second valve to add power angle on my plow. Some came with a 2 valve system with front ports, which is what I would like to do. I have a extra single valve and was wondering if I could use this or if I need a new valve. Thanks.
18' Pipe Gate (A66408)
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
7002SFL (A61572)
7002SFL (A61572)
2002 Freightliner FS65 School Bus, VIN # 4UZAAXAK02CK16471 (A65563)
2002 Freightliner...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
1500-gallon Poly Tank (A66408)
1500-gallon Poly...
