Adding a rear remote to a CK25...
/ Adding a rear remote to a CK25... #1
BigDogues
New Hampshire
Kioti CK25hst
Hi,
As I am now the proud owner of a brand new CK25hst, it's time to start with the modifications. /forums/images/graemlins/grin.gif I would like to add a rear remote valve and ports so that I can move my snowblower chute. I seem to be having difficulty in explaining exactly what I am looking for to my dealer. He had given me a estimate of over $1000.00. /forums/images/graemlins/shocked.gif I had seen a CK20 that had the remote lever and one set of ports already on it. I want to do the same thing. Can someone tell me what parts I should order to add this valve and the remote parts? Where is good place to order the parts from? I'm fairly mechanical and don't mind doing the work myself.
Thanks in advance,
Phil
/ Adding a rear remote to a CK25... #2
Congratulations...................seems dealers having these machines in stock is a chore in itself. What dealer did you use? I'm guessing it is the same remotes used for a backhoe. If so the dealer should know what those are
/ Adding a rear remote to a CK25... #3
I think I got an estimate for around $350 for the kit to have 1 set of rear remotes, you may want to contact other dealers, or maybe some one here has the kit Model number. That way you can tell your dealer what you are looking for and give you the correct cost.
I' plan on adding remotes to mine, but right now I have nothing that uses rear remotes. I'd hope to build something that would use them such as a log splitter, or something...
Good luck
/ Adding a rear remote to a CK25... #4
I bought mine with two rear remotes, it took about a month for them to come in though. They ran about $450 ea I believe.
Yeah, he told me about $350 for one set of ports, but with out a control valve and lever. Can't believe it would cost so such more for just that. /forums/images/graemlins/confused.gif
/ Adding a rear remote to a CK25... #6
Most manufacturers make a killing on remotes. If your dealer is compitant they can build their own remotes for less $$.
/ Adding a rear remote to a CK25... #7
One set costs 276 add a second set for 375. Total for 2 sets...List price $650.
KO
/ Adding a rear remote to a CK25... #8
Sounds like your dealer is a little thick.
As Kiohio stated, they don't cost $1000.
Very easy to install yourself as well.
You can order them through any Kioti dealer who's willing to ship if you don't want to get them from the guy you're dealing with.
My dealer ships as well as many other members here.
www.bigtractorsupply.com Dave Williams
John
Like I had said he gave me what might be a reasonable quote to add one set of remotes but he is telling me it is lines only with no control. I would have thought that a control valve would be part of the kit, no? He suggested picking up a aftermarket valve to go in after the ports. I want the factory A/B position lever mounted in the operators area where it suppose to be. I wanted to have this so I could move my snowblower chute as well as perhaps control a woodsplitter or whatever if I decided to add one later. In his defense, it is rather difficult to figure out what you need without a detailed or illustrated parts list. Does Kioti have exploded parts diagrams available? I don't suppose you know where I could lay my hands on one?
/ Adding a rear remote to a CK25... #10
The kit includes EVERYTHING you need to installed the remote valve, all the way down the decals and rubber handle grip for the lever.
The kit does NOT included just lines, but everything that is needed.
/ Adding a rear remote to a CK25... #11
It is as Jon said. Everything you need. Valves, lines, handles, Quick couplers, etc.
KO
/ Adding a rear remote to a CK25... #12
I concur with that. I bought a set from my dealer. It comes complete for one set of remotes. Nicely designed. The instructions aren't bad and it was fairly easy to install. (couple of hours if I remember right)
/ Adding a rear remote to a CK25... #13
Hi,
You have to realize that there are 2 different kits your dealer can provide. 1st is a hose kit(looks like remotes) for a backhoe set-up. It attaches to the side of the trans housing hyd block. It has a small valve that turns it on and off. It is NOT directional like remotes.
2nd is a rear auxilary hyd valve kit #322026 which has a directional handle and attaches to the same block as the hose kit. the difference is the handle position changes the flow direction of the oil(snowblower shute, log splitter etc) it is a little complicated to install because of confined spaces.
The hose kit sells for less than $200 and the rear remote kit sells for less than $300 (cash and carry) no installation. A good man can install in about an hour.
Any Kioti dealer should be able to supply these kits(sometimes they sell out) as they are generally available.
Good Luck
Kioti Dave
/ Adding a rear remote to a CK25... #14
Sooooo, if I have a backhoe, I have a hose kit? Can the rear remote for TnT be added cheaper because I have the hose kit? Confused...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61573)
2012 Toyota Tundra...
