Adding a Horn to a Kubota Grand L non cab tractor
   / Adding a Horn to a Kubota Grand L non cab tractor #1
Kubota Tee
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
I'm ready to start my next tractor mod - this one I consider a safety item. I'm going to add a horn to my Grand L 3540HST. After reading through several posts here and on other tractor forums, there seems to be a possibility that my Grand L may already have the basic wiring in place. So, I'm reaching out here to all TBN'ers who have done this project on their Grand L non cab model to see if you were able to find this mystery wiring connection.
I plan on installing a Stebel compact air horn that I just ordered off the Internet. It's rated at 139db, so should be able to get everyone's attention if I need to. Here's a pic of the horn I ordered. They call it the "stealth" version because of the Matt Black finish. Should hide really nicely under the hood.
   / Adding a Horn to a Kubota Grand L non cab tractor #2
Is there a slip ring on the steering column, or are you thinking of wiring to a button on the dash?
I'm interested as I have a similar tractor and would like to add a very loud horn for the benefit of my neighbors banana-head dog who always seems to be on the verge of going under my tractor when it's moving. I like my neighbors, and I like their dog, even though he may not be the sharpest knife in the drawer.
   / Adding a Horn to a Kubota Grand L non cab tractor #3
I would do the dash with a simple push botton. Super soaker water gun will train just one dog.
   / Adding a Horn to a Kubota Grand L non cab tractor #4
You mean the Grand L does NOT come with a Horn?
   / Adding a Horn to a Kubota Grand L non cab tractor #5
I suspect that adding it using the stock wiring would entail replacing the headlight/turn signal switch as that's where the horn button on the RTV500 is.
Aaron Z
   / Adding a Horn to a Kubota Grand L non cab tractor #6
Aaron Z
that is exactly how the Kioti works..Horn button in the middle.. I wonder if they are the same switch?. Here is what the Kioti looks like.
Baby Grand,
Not sure about the slip ring as I haven't taken a look at that yet. If there is no wiring there, I guess I'll be adding a push button on the dash. I know what you mean about the dogs and in my case, it's my own who thinks he needs to always be right out in front of me whenever I take the tractor over to our two park areas to mow. We also have small children in the neighborhood and they don't always pay much attention to their surroundings. I should be able to get their attention with the Stebel!
Will probably end up going that route - with the push button that is :). I don't own a super soaker.
I think the cab models do come with horns, but my Grand L 3540 did not come with one. I know that many companies try to reuse common components like wiring harnesses as its cheaper to make just one config even if you don't use all of it on a certain model.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=335998"/>
On the Grand L models that have a horn, it's a separate push button. On my grand L, the turn signal activator is on the column like a car. It's integrated with the headlights switch (you twist the turn signal activator to turn on the headlights). The photo is a little blurry, but you can see the turn signal handle (black on the right of the steering column) with the word "Off" on it showing the headlight switch.
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
