Adding a back up light on the ROPS
/ Adding a back up light on the ROPS #1
norbie454
Oxford Hills Maine top-o-da hill
Kioti LK3054
I have a Kioti LK3054 and want to put a light on the ROPS so I can see when plowing in reverse with a 3 pt hitch blade at night. There is a 6 wire connection behind the seat but which wire is the power? I do not have a meter to check the power source. I was hoping someone has done this in the past and could pass on their learnings. I would appreciate it and wish you all a merry Christmas.
Norbie454
/ Adding a back up light on the ROPS #2
How about a test light, (if you don't have a meter), they are cheap, and will tell you which wire(s) are hot when your light switch is on.
Thanks great idea where was my head, DUH.... I hooked up the light and connected a wire to it and used that as my test light. Low and behold the blue wire was the hot one. thanks for clearing my head. I attached a photo so you can see my results. Not sure if I did this right but here goes anything.
/ Adding a back up light on the ROPS #4
Thanks, but you deserve the credit- I didn't consider using your actual light as your test light ;)- glad it worked out for you!
Merry Christmas / Happy Holidays to you and everyone on TBN :thumbsup:
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
(3) Wheels and Tires for 4-Wheeler (A65579)
(3) Wheels and...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
