Adding a 12volt outlet
/ Adding a 12volt outlet
Roy, i shot you another PM
Got it!!! And responded!
BTW, TBN is one of the very few websites I allow pop ups...I read your PM before I opened this thread.
/ Adding a 12volt outlet #83
ok, oh. I did a fast drawing and allowed 0.10 In for metal loss at bending. IS this ok then
/ Adding a 12volt outlet #86
Heres Roys mounting plate. Off to powder coater tomorrow. Still have to drill 4 drain holes
Looks great, Greg!!! I'll be the envy of the neighborhood!!
/ Adding a 12volt outlet #89
Well i have help... love my plasma cutter. Heres a youtube vid of the cutting of this piece. I just did it to see if i could video the cutting. Its so bright i didnt think it would work. Had a depth problem at the start, but fixed that and continued the cut.
roys0001.mpg - YouTube
Very impressive!!
So, why do you have a plasma cutter? Is it for you contracting work, or mostly home projects?
/ Adding a 12volt outlet #91
Very impressive!!
Both actually. I got it originally to do metal art stuff that the wife sells, and then moved into making connection brackets for log and timber homes. Now that building custom homes is nearly ZERO, im using it for mostly for projects.
I built my main gate with it, sign posts, things like that.
It really is a hoot to play with, though at times its a pain in the butt...those times when for no reason at all it just doesnt want to cut fully thru the metal.
Wow! That gate is very impressive!!
I assume it's CNC? What do you use to program it?
/ Adding a 12volt outlet #93
Im too crummy of an artist to do it by hand. I use either autocad or CoralDraw to do the artwork. My wife did most of the artwork for this gate. She did the basic design than i redrew it to add some internal strength areas to try and prevent sagging. Needless to say it weighed about 600# when finished.
The fence is vinyl, with plastic posts. So i took a 5x5 x 1/4" steel column and plasma cut 3 holes for the vinyl fence and had it powder coated white. Now the gate hangs from this post set 4' into the ground in tons of concrete :laughing:
No sagging or dragging for this baby.
/ Adding a 12volt outlet #94
Wow! That is impressive! Well Roy, you must have some other projects in need of metal work for GRS to manufacture and video so we can enjoy the show, don't you? :)
LOLOLOL!!
Well, I could come up with others...but, how about you?
I would love to have two of those custom gates! Nice work sure would look better than the tube gates I got!:laughing:
Good chance grsthegreat would accomodate you...just ask him!
/ Adding a 12volt outlet #100
Well, all done. Just got it back from powder coater. ready to ship...
INOP/NON-RUNING Genie GS3232 Scissor Lift (A65579)
INOP/NON-RUNING...
John Deere Pallet Forks (A66285)
John Deere Pallet...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
