Adding 3 spool valve to JD 4020
   / Adding 3 spool valve to JD 4020 #1
jackmac
MF 130
First I would like to apologize if this has already been addressed but I did a search I could not find the information. I am wanting to add a 3 spool valve to my 4020 to operate a batwing mower. I would like two of them to have the float option. Where can I tap into the hydraulic system to have this operate correctly? Would I simply just have a supply and rerun line?
Thank you for the info. Do you have any idea or suggestions on where to tap into the hydraulic system on the tractor?
   / Adding 3 spool valve to JD 4020 #4
I am not that familiar with JD's, but I believe there is an accessory block toward the back.
Look at your owner manual and it should provide the info you need.
   / Adding 3 spool valve to JD 4020 #5
Our 1967 4020 has a 3 spool vavle mounted on the fender so you can operate it with your right hand. We run our FEL with the 3 spool vavle (only use 2 of 3 vavles). It has quick connects that we disconnect the hoses for the FEL (but leave the loader on) and plug in our 3 batwing hoses. The valve is run from the rear remotes.
I have a bradco root-rake grapple for my Kubota M9450. If I can find or make an adapter plate for the JD 148 FEL, I'd like to utilze the 3rd vavle to run the grapple with the 4020 if needed.
   / Adding 3 spool valve to JD 4020 #6
This brings up a question about float.
If you have a two lever valve and one of them is in float, the first spool, can the other lever be in detent, and still function?
Is there any flow to another downstream valve via the PB port?
   / Adding 3 spool valve to JD 4020 #7
1967 model 4020 doesn't have a detent or float function, you'll have to be the float.
   / Adding 3 spool valve to JD 4020 #8
That was just a question, not relative to any model in particular. Just related to theory of operation.
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
