Around here, we get "winter blended fuel" seasonally , right out of the pump."The Kioti manual tells you NO fuel additives". What about anti gel in the winter?
The tractor is supposed to know what you have attached and limit the lift accordingly?I paid for the fender. The Attachment shouldn’t collide or interfere with the tractor. It was sold by the Kioti dealer. I didn’t buy it aftermarket.
You can buy the same thing: I did. Not sure how easy to install as I just never got around to do it.Mine has a limiter on the down side, but it doesn’t look like it would be that difficult to rig something!!
Installing a quick hitch with a shortened top link can mangle fenders and more on many tractorsShag,
Sell your tractor and don’t look back. Way too many hassles already and lack of confidence. A lift arm that you can raise high enough to break your fender is BS engineering. No excuses for that though some try to make them. No wonder you are having so many problems, pigdin engineering. Then go buy yourself a good old Ford from the ‘60s or ‘70s and will it to your grandkids. The newer tractors all have confounded electronic this and that which probably will be a source of headaches down the road, especially when the mice figure out the wiring is wrapped in yummy soy insulation. Good ole American steel, and only points, rotor cap, and condenser to worry about for electrics. Something wears out, pull it apart with your SAE wrenches and fix it yourself.
Shag,
I start to pull the lens cover off and it’s filled halfway with water. Ok, that’s why the light went out, but there’s no damage to the cover to cause it to crack. I check the other lens cover and it also has a crack, but no water. Also it’s not showing any damage.
My buddies 2 year old durange has led driving light on driver side burn out. Its sold as a complete light assembly. $1,800 plus install labor.
I was told I put bad or adulterated diesel into the tank).
I think this was bunk.....but here is the circular logic....."the diesel in the tank did not smell right" - where do you get your diesel fuel?dditives.
I agree that quality control has been sinking. I have owned my Kioti for 22 years and it has never failed to perform like new. 3-year old Korean refrigerator has been nothing but problems. When my son's Korean car motor failed, dealer got approval to replace it since nearly all were bad motors. Trouble was, the wait time for a new motor from Korea was one year. USA manufacturing must return!
I had a Mercury Sable Wagon that did this. The headlights would periodically fill with water and at night once the headlamps heated up any bump would cause the water to hit the bulb and crack it.
My theory was that the evening sun expanded the air in the headlight assembly and the resulting pressure forced the air out past the seals. The cool damp evening air would then be drawn in by the resulting lower pressure inside the assembly and then condense eventually collecting enough to cause a problem. Total BS? Maybe, I said it was a theory.
Anyway, the cure was removing the headlight assembly and drilling weep holes in the bottom of each. Never had the problem again.
