Add float to a loader that doesn't have it?
   / Add float to a loader that doesn't have it? #1
UHI
UHI
Is it possible to add float function to a front end loader that doesn't have it as standard? Is it just a case of changing the spool valve for the loader lift circuit, or is there something else required?
Cheers
   / Add float to a loader that doesn't have it? #2
You would need a new valve.
What machine are you working on?
   / Add float to a loader that doesn't have it? #3
Unless it's more than 30 something years old it's probably a loader valve.
1 stick to run lift and curl.
But replacing the valve for lift is the solution.
You need to know flow required, open vs closed center, and fittings.
   / Add float to a loader that doesn't have it? #4
What kind of tractor and loader do you have ? Your signature indicates your tractor is UHI ? I have never heard of that brand tractor before.
Ok here is some information about UHI equipment
AI Overview
Learn more…
UHI tractors are manufactured in Chinaby XCMG, the world's third largest earthmoving equipment manufacturer. Some components of UHI tractors come from other companies, including Kubota diesel engines, Rexroth hydraulic pumps, and Eaton slew and track motors.
UHI tractors are competitively priced and are popular with smaller landscaping contractors, farmers, jobbing builders, and agricultural contractors. Some say that UHI tractors are a good choice for equipment that won't be used too often because they are more affordable than tractors from bigger brands.
Some Fords all you have to do is turn 1 bolt to a different position and down pressure will be turned off so float will start working
   / Add float to a loader that doesn't have it? #5
Float can be added via externally mounted electrical valves but depending on tractor and loader might be less expensive and easier to replace the loader valve.
Kubota BX25D (A53317)
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
