Add a valve control for grapple on Case/IH JX 55
   / Add a valve control for grapple on Case/IH JX 55 #1
easyrb
Red Rock, Tx
Case/IH JX 55
I have a Case/Ih JX55 with fel. The tractor came with joystick but not the control valve to use it. I want to add a grapple, the dealer wants $1000 to add the valve control to use the trigger. I've thought of just getting extra hose and using the rear connections to control the jaw ( rarely used otherwise). Suggestions or experience with this? Thanks
   / Add a valve control for grapple on Case/IH JX 55 #2
Many people do this and it works out just fine for them. It is by far the cheapest route to go. Do some shopping on line for your hoses. This will get you the best price for custom length hoses. I suggest using 3/8" hose, but many recommend 1/4" and that is really all that you need for a grapple. Cheaper and easier to route.
Try these guys if you don't know where to shop. :thumbsup: http://www.hydraulicstore.com/hydraulic.html
   / Add a valve control for grapple on Case/IH JX 55 #3
Thought the hoses would be more expensive, had some made for a top link that cost me $100+. Ckecked on line and every thing for the hookup, hoses and connectors, for around $100 total, I can reach behind me for that. versus several $100s
to use the trigger on the joystck.
Thanks
1990 KME (A53424)
1990 KME (A53424)
2016 Freightliner M2 106 Braun Ambulance (A55788)
2016 Freightliner...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
9202 (A50322)
9202 (A50322)
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
