Add a valve control for grapple on Case/IH JX 55
   / Add a valve control for grapple on Case/IH JX 55 #1
easyrb
Red Rock, Tx
Case/IH JX 55
I have a Case/Ih JX55 with fel. The tractor came with joystick but not the control valve to use it. I want to add a grapple, the dealer wants $1000 to add the valve control to use the trigger. I've thought of just getting extra hose and using the rear connections to control the jaw ( rarely used otherwise). Suggestions or experience with this? Thanks
   / Add a valve control for grapple on Case/IH JX 55 #2
Many people do this and it works out just fine for them. It is by far the cheapest route to go. Do some shopping on line for your hoses. This will get you the best price for custom length hoses. I suggest using 3/8" hose, but many recommend 1/4" and that is really all that you need for a grapple. Cheaper and easier to route.
Try these guys if you don't know where to shop. :thumbsup: http://www.hydraulicstore.com/hydraulic.html
   / Add a valve control for grapple on Case/IH JX 55 #3
Thought the hoses would be more expensive, had some made for a top link that cost me $100+. Ckecked on line and every thing for the hookup, hoses and connectors, for around $100 total, I can reach behind me for that. versus several $100s
to use the trigger on the joystck.
Thanks
2015 KUBOTA RTV 1140CPX (A51406)
2015 KUBOTA RTV...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
2008 Dodge Avenger Sedan (A55758)
2008 Dodge Avenger...
