add a cylinder
/ add a cylinder #1
dixstir
fairmont mn
2305 jd cub farmall home made tractor
I have a jd 2305 it has a loader and a jd manual diverder valve how can I add another double action cylinder and still use my loader controls,
/ add a cylinder #2
What is the new cylinder for?
What do you use the diverter for (I assume the independent MMM lift)?
You can add a new valve that would allow you to operate the MMM and the "new cylinder" one at a time, or even even a 2-spool valve that would let you keep them both hooked up at the same time. If it's for a grapple there is an even easier way...please tell me what your goal is;)
/ add a cylinder
2305 add a cylinder-I want to turn my snow blower chute and may be use it on my hyd traile dump
/ add a cylinder #4
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
ELECTRIC CHAIN HOIST (A64278)
ELECTRIC CHAIN...
