add a cylinder
/ add a cylinder #1
dixstir
fairmont mn
2305 jd cub farmall home made tractor
I have a jd 2305 it has a loader and a jd manual diverder valve how can I add another double action cylinder and still use my loader controls,
/ add a cylinder #2
What is the new cylinder for?
What do you use the diverter for (I assume the independent MMM lift)?
You can add a new valve that would allow you to operate the MMM and the "new cylinder" one at a time, or even even a 2-spool valve that would let you keep them both hooked up at the same time. If it's for a grapple there is an even easier way...please tell me what your goal is;)
/ add a cylinder
2305 add a cylinder-I want to turn my snow blower chute and may be use it on my hyd traile dump
/ add a cylinder #4
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
2017 Ford Fusion (A64557)
2017 Ford Fusion...
Pig Statue (A64557)
Pig Statue (A64557)
2022 EZ-GO ELITE...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
