add 3rd function to L3400
/ add 3rd function to L3400
Thank's knight, I've got to pick up a repair manual. going to order parts,will post how it goes. FeLL is LA463.
/ add 3rd function to L3400 #12
WILLIE, you can buy a simple monoblock lever-actuated spool valve,
like the Prince unit from Northern. Don't forget the Power Beyond
sleeve, cuz your 3-PT is normally powered from the PB of the FEL
valve. You can install your new 3rd function valve between the FEL
and 3-PT. Cost will be $100 for the valve, plus a couple more hoses,
some fittings, and a mounting bracket. No need to spend $800.
Thanks for the info, I searched northern's site no luck finding anything on a power beyond sleeve,What does it do?
/ add 3rd function to L3400 #14
I used a electric diverter valve on my grapple cost 250.00 including fittings just plumb your tilt cylinders in and out again push button close open grapple release button tilt bucket normally
I've bought the dirverter valve and base, how do I run the return line ?
/ add 3rd function to L3400 #17
What return line? If you bought a solenoid-operated diverter, it prob has
two pressure inlets from your mechanical valve, and four outlets that
go to your cylinders, 2 to one, and 2 to the other. If your cylinders are
paired, then your diverter outlets get teed into each pair.
I just checked with NorthernTool and you are right that I do not see many
explicit listings for the power beyond sleeves for their Prince valves. A
buyer would probably have to ask to get them. You won't need a power
beyond setup since you are going to divert the flow from a work circuit
on an existing valve.
/ add 3rd function to L3400 #18
I added this an electric over hydraulic control to my M6800. WR Long sells the entire kit, set up specifically for each model tractor. Mine costs around $600 if I remember correctly. My dealer installed it but it would not be too hard to do it yourself. It did require a little welding to attach the quick connect bracket to the FEL. You can go to the WR Long website to see this. They were really nice to work with.
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2001 International 4000 DT 466E (A60462)
2001 International...
