AC MAXIMUM/B3030 CAB.
/ AC MAXIMUM/B3030 CAB. #1
lawn_king
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
I had to run my AC on full throttle, for the first time. I was running rear pto @ 2000 rpm, in full sun, 82 degrees. She kept me comfortable but the fuel gage was constantly on the move,down! :cool:
/ AC MAXIMUM/B3030 CAB. #2
I've never seen an air conditioner do anything different!
I can live with the big fuel consumption. Two long days of spraying would have been a drag on an open station machine.
/ AC MAXIMUM/B3030 CAB. #4
Well.... we've been in the 90's everyday and I don't have a cab!!
/ AC MAXIMUM/B3030 CAB. #5
Are you running the cab on outside air or recirculating the air? Recirculate will reduce the cooling load,reducing the compressor on-time. Or provide a lower inside temp,reducing the amount of heat the AC system has to carry away from the cab,hence reducing the load on the compressor. I believe these have a cycling clutch system,so the compressor runs as needed,then freewheels,until a cycle is needed at all. Engine speed should only affect how long the compressor runs per cycle,not how much work is required. Please excuse the rambling on. Good Day.
I run it in the recycle position, every hour or so i bring in a little fresh air then go back to recycle. Fuel consumption increases around 20% with the AC on.
/ AC MAXIMUM/B3030 CAB. #7
Howdy,
If you are running at high RPM just for the A/C to work right you may want to check and see if the freon is a little low. My B3030HSDC cools good at 1500 RPM or less, but after 15 minutes it will freeze you out of the cab even on really disgusting days. It cools enough for condensate to form heavy on the glass on the outside of the cab :)
Jeff
/ AC MAXIMUM/B3030 CAB. #8
If a 30HP tractor consumes about 1 gallon per hour at RPM(sounds reasonable,eh?),then a 20% increase would mean .2 gal/hr for air conditioning. An eight hour day would be an extra 1.6 gallons used,@ #3.00/gal would mean $4.80 per full day to use the AC. Sounds worth it to me!
/ AC MAXIMUM/B3030 CAB. #9
Fuel is a concern to most all by way of operating expense. But once I reach a certain point of investment for utilization and comfort, fuel comsumption is not an issue to me. Glad to hear your AC is serving you well. Makes me want to move up to a cab model.
/ AC MAXIMUM/B3030 CAB. #10
kubotafan said:
I have a B7500 and was wondering how the B3030 would compare. I know it would be more, but have never seen or heard how much more.
You can spec them out on Kubota's web site. Money wise, I'm thinking about US$3000.
I almost bought the 3030 open model, but the additional gadgets weren't appealing to me. Now that I would consider an enclosed model, I'd do it in a heartbeat, had I have not just bought this 7800. They are the same tractors other than options and the different hood design.
The B7800 & the B3030 are far from the same machine! From the pto to the 3 point hitch, from the lower links to the cruise control, from the hydraulic outlets to the style, very different, Both fine machines, but very different.
kubotafan said:
My post was linked to the previous post where the subject of FUEL CONSUMPTION was being discussed, NOT PRICE. Can someone give me an idea on fuel consumption? Lawn_king, you had a B7500. How does the fuel consumption compare with the B3030?
I never owned a b7800, i owned a b7500. The 3030 consumes more fuel as you should expect (4 cylinder & 9 more horses) however you get so much more for the additional consumption.
/ AC MAXIMUM/B3030 CAB. #13
I recently moved up to a B3030HSDC from a B1750HST. Serious difference! I had the B2660 5 foot front snowblower with it. The 20HP B1750 really handled the 5 foot blower better than one would think,but it wasn't hard to keep it full enough to keep the engine maxed right out all the time-full load at full RPM=maximum fuel consumption. I always got 2/3 gallon/hour. My place is a one hour snowblow or plow job(yes,time is equal)and every third time,I could put in 2 gallons. Mind you,that's absolutley all the fuel that could possibly be put through that engine.
On another note,a neighbor has a L3010 30HP hydro and he reports 1 gallon/hour when he's really working it.
This leads me to conclude(hey,I've been wrong before)a 30 HP diesel would be expected to use about 1 gal/hr in hard use. Of course,lower RPM's and lighter load would reduce that figure. And then one would have to factor in the AC usage-Lawn King reports a 20% increase in fuel use with AC at high RPM. I'm taking him to mean it was more noticable when using the tractor hard. I don't have enough experience with mine to comment on how much extra the AC uses.
And then I think about the tanker loads of gasoline I've poured into my old Dodge Power Wagon in 20 years of plowing and these tractors seem to make fuel! Hope this helps and wasn't too boring. Good Day.
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2019 FREIGHTLINER...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2003 Coleman Pop Up Camper (A62613)
2003 Coleman Pop...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
