AC circuit short issue cab internals
/ AC circuit short issue cab internals #1
Dandolore
Florida
LS 4040 and Farmall 130
After fixing a circuit short in my AC compressor clutch, I reassembled my Tractor cab and turned on the AC unit. Initially, everything seemed fine for about 2 seconds, but then a loud POP sound occurred. I ruled out fuse issues. However, I later discovered that I accidentally swapped the AC temp dial and blower fans plugs, which I believe is the cause of the issue. Beyond looking at the fuses what else should I try? LS XR 4040h/NH Boomer 41
/ AC circuit short issue cab internals #2
Sounds to me like a failed refrigerant hose. Did you overcharge the system? Hopefully not a failed-ruptured evaporator. They are expensive in any unit.
/ AC circuit short issue cab internals #3
Pinch wire.
/ AC circuit short issue cab internals #4
Fuses relays and start tracing wires. Shouldn't be too complex as vehicle AC is pretty simple, electrically.
I am assuming you have an electrical problem from what you said, but re-reading that is not clear.
/ AC circuit short issue cab internals #5
The temp control is typically just a rheostat. You probably burned that but may not be the worst. Feeding 12v to the controller when it expects to see a resistance most likely fried the controller. Without having a diagram of your system, it's hard to say.
I did purchase a new controller thinking that was the issue as well but it didn't fix the issue. I believe I have a spare thermostat somewhere. I'll give that a shot as well.
/ AC circuit short issue cab internals #7
Not thermostat, rheostat. It's a variable resistor.
