AC circuit short issue cab internals
/ AC circuit short issue cab internals #1
Dandolore
Florida
LS 4040 and Farmall 130
After fixing a circuit short in my AC compressor clutch, I reassembled my Tractor cab and turned on the AC unit. Initially, everything seemed fine for about 2 seconds, but then a loud POP sound occurred. I ruled out fuse issues. However, I later discovered that I accidentally swapped the AC temp dial and blower fans plugs, which I believe is the cause of the issue. Beyond looking at the fuses what else should I try? LS XR 4040h/NH Boomer 41
/ AC circuit short issue cab internals #2
Sounds to me like a failed refrigerant hose. Did you overcharge the system? Hopefully not a failed-ruptured evaporator. They are expensive in any unit.
/ AC circuit short issue cab internals #3
Pinch wire.
/ AC circuit short issue cab internals #4
Fuses relays and start tracing wires. Shouldn't be too complex as vehicle AC is pretty simple, electrically.
I am assuming you have an electrical problem from what you said, but re-reading that is not clear.
/ AC circuit short issue cab internals #5
The temp control is typically just a rheostat. You probably burned that but may not be the worst. Feeding 12v to the controller when it expects to see a resistance most likely fried the controller. Without having a diagram of your system, it's hard to say.
I did purchase a new controller thinking that was the issue as well but it didn't fix the issue. I believe I have a spare thermostat somewhere. I'll give that a shot as well.
/ AC circuit short issue cab internals #7
Not thermostat, rheostat. It's a variable resistor.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
HPX John Deere Gator (A65579)
HPX John Deere...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
