About to order RK55, question on rear remotes
   / About to order RK55, question on rear remotes #21
I emailed RK with the same question and here is the reply:
"Thanks for reaching out to RK Tractors. Yes we do offer an accessory rear remote and the part number is 15175080300 and it sells for $348.60. The labor to install would be 75.00."
Downside is the kit comes with a spring center valve like on remote "A"
I tried to order just the end cap to convert it to detent float but got nowhere.
Finally, I just ordered part number 12285080941 Valve, auxiliary external floating/D. Same as is currently on remote "B".
I don't even know what the price is going to be until they actually place the order sometime today or tomorrow.
Meanwhile, I ordered 3 and so far installed 2 bidirectional flow regulator valves from agri store for $30.53 each. They work really well for slowing down the top and tilt cylinders I have installed.
To be continued,
Hoochy.
   / About to order RK55, question on rear remotes #22
To be continued,
Hoochy.
Can you give any more details on the regulator valves you used? Were they similar to this one from Agri Supply Adjustable Line Throttle Valve ? Did you add one per cylinder or two, and if only one was added which side of the cylinder did you install it?
   / About to order RK55, question on rear remotes #23
This is what I used
Two-Way Hydraulic Flow Restrictor | AGRISTORE USA
They are bi-directional so you can mount them on either side when using double acting cylinders. One per remote will do. For single acting cylinders such as the wings on a batwing I would place them on the side that reflects what the cylinder will do when you actuate the lever.
Hoochy
   / About to order RK55, question on rear remotes #24
Update on valve 1228508941, ... $278.00.:eek: a week to 10 days to receive at my local RK dealer.
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
Giyi 59" Compactor Wheel (A57149)
Giyi 59" Compactor...
