Mowing ? about JD 755 mower deck
   / ? about JD 755 mower deck #1
chico922
Rockford,IL
John deere 755
I would like to buy a mower deck with a bagger for my JD 755. If anyone could give me the model number for the deck so i can shop for one it would be helpful. My local john deere delaer wil not give me a stright answer without selling me something first.
chico922@excite.com
   / ? about JD 755 mower deck #2
Chico922,
Keep an eye on ebay (try searching for John Deere 755) and you might just see one of those pop up. I've seen all kinds of stuff for the 755, 855, and 955. I check it regularly just in case someone wants to "give away" a backhoe. /forums/images/graemlins/smile.gif
   / ? about JD 755 mower deck #3
The model number on my 1987 JD 755 60" MMM is MO2732, but the way JD changes things all the time this number may not be good for earlier or later years. About half of the time I go to my JD dealer with a part number from one of parts catalogs I bought with the tractor, I find the number is no longer valid. It has been changed to something else. I am not sure about a bagger. I think JD made one that mounts on the 3PH as well as a hydraulic dumping hopper.
Good Luck on your search.
Jeff Rowe
   / ? about JD 755 mower deck #4
The SN label on my 1989 755 60" mid mount mower also says M02732. By the way does anyone have a manual on this MMM . When I switch in the MMM it blows a good bit of smoke before the mower get up to speed. I've pulled it off and hit all the zerks with greese and cleaned everything up. All the spindle bearings seem free. Should I swap out the dope in the gearbox, and if so with what? Thanks in advance.
Reg in SC
   / ? about JD 755 mower deck #5
"When I switch in the MMM it blows a good bit of smoke before the mower get up to speed"
The only time I've seen that was when my RFM belt slipped off the pulley. The belt was dragging and abrading between the pulley and mower deck. You might want to see if your belt is a bit slack or you've a dragging pulley.
BTW, does it smell like burning rubber?
   / ? about JD 755 mower deck #6
RegWaters,
The smoke may be a slipping belt. The initial startup places a higher load on the belt than when running. There is a tensioning spring located on the right side. In the attached photo it is just below the center spindle. The spring could be broken or missing. Also check the tensioning pulley pivot point for free movement. If this has frozen up due to lack of lubrication it may not allow proper tensioning of the belt. Finaly, check the condition of the belt to make sure it has not glazed over. You may need to replace it.
I have both the Operators Manual (publication # OM-M91324 Issue E6) and the Parts Catalog (publication PC-2114)
This past spring I tore my deck down to rebuild it. After 15 years of sitting in the weather (stored under cover in the winter), the deck was badly rusted. Spindles, gear box, lift arms, etc. were fine. I had the deck sand blasted and repainted starting with an epoxy primer. The deck was still solid despite the rust.
Let me know if I can answer any other questions on this deck.
Jeff
   / ? about JD 755 mower deck #7
RegWaters,
Here's a photo of the deck before sand blasting. I'll send another post with an after photo.
Jeff
   / ? about JD 755 mower deck #8
This is the what the deck looked like after a little cleanup.
Jeff
   / ? about JD 755 mower deck #9
So...what's that in the background?? An aircraft?
   / ? about JD 755 mower deck #10
Roy,
Yes, it is a 2 place amphibian aircraft (Searey) I am in the process of building.
Jeff
   / ? about JD 755 mower deck #11
<font color="blue"> There is a tensioning spring located on the right side. </font>
/forums/images/graemlins/crazy.gif
Sorry Reg, this should have read:
There is a tensioning spring located on the left side.
Jeff
   / ? about JD 755 mower deck #12
Thanks for the Info ! I should have been more specific. The smoke is coming from the engine exhaust as the momentum load from the deck lugs down the RPM's. When engage at 2800 rpm it drops to about 2000, then comes back up. I looked at it a little closer under operation ( carefully) and the left spindle seems to be vibrating slightly. Well I need to put a fresh set of blades on it anyway , I guess i'll tear it down and have a look.
Reg in SC
   / ? about JD 755 mower deck #13
Reg,
I just tried engaging the MMM on my 755 as you did for a comparison. RPM set at 2800, engaged PTO, RPM briefly drops to around 2100 and returns to about 2700. Needle movement is continuous in its drop and return. I do not get any smoke so there may be something going on with your engine (fuel quality/type, air filter) that it smokes under load. By the way, the manual for the MMM suggest engaging the PTO at the "one-third speed position" then increasing throttle to "Fast" position once MMM is running.
Good Luck.
Jeff
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
2018 HINO SA (A58214)
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
