A RoundUp & Pump Sprayer Question
/ A RoundUp & Pump Sprayer Question #1
GaryM
Warrenton MO
JD4100 Hydro
I use RoundUp, the real stuff, in a 2 Gal. pump sprayer to keep my gravel drive clean. I also use it to spray around obstructions such as light posts etc. I mix according to the listed directions.
I often don't use up all that I've mixed, so leave it in the sprayer. Sometimes a half gallon or a little more. Often the next time I go to use it, it won;t spray. I find the screen just before the nozzle clogged with "glop" that's restricting the flow. I have to remove the nozzle and screen to clean it out. It's kind of thick and whitish looking. I can remove it by rinsing and a little scrubbing with a brush.
Anyone else run into this issue? I hate to dump and rinse the sprayer each time I use it, that stuff's not cheap.
Thanks.
/ A RoundUp & Pump Sprayer Question #2
I have the same issue. I just mix what I can use in a few days and all's well.
/ A RoundUp & Pump Sprayer Question #3
Gary, I used to have that problem until I started pouring any left over mix I had into a labeled jar to use the next time and then I rinse out my sprayer and run fresh water through the hose and nozzle...Next time I pour the left over in and add water and more concentrate to the mix....I try to use it all but it always doesn't work that way and I don't want to waste it....so I know what you mean.
/ A RoundUp & Pump Sprayer Question #4
Roundup eats metals, so anything it comes in contact with is going to be affected. You can buy commercial neutralizers, like Nutrisol, but (as Brin says) it is best to empty the tank and flush the lines with water. If you want to keep the leftovers, it is best store it in a separate plastic container, IMHO.
/ A RoundUp & Pump Sprayer Question #5
I get the feeling you are using the concentrate with no water . Please explain .
/ A RoundUp & Pump Sprayer Question #6
According to his 1st post he says he "mixes according to the listed directions"
I'm using RoundUp Super Concentrate 50.2% Glyphosate, mixing 2.5 Oz. per gallon of water according to the label mixing instructions. The sprayer is an RL Pro Model 996P "Powered by Solo". No known metal parts, looks to be all plastic. I usually mix 2 gallons and spray whenever the weeds start to annoy me. So it may sit in the garage for two weeks or so between uses.
/ A RoundUp & Pump Sprayer Question #8
When you are finished spraying turn the sprayer upside down and spray the till the mixture is out of the wand. Just like you would do with an aerosol paint can. Just make sure your pump is sealed tight.
I don't have any problem with my backpack sprayer because it never sits more than a week at a time.
The little pump sprayer I use around the house to spot spray with may sit 2-3 weeks. I had the same issue and started turning it upside down and spraying until nothing was coming out. Then turn it back over and let it sit until the next time I need it. No liquid in the hose or nozzle.
Also once you clear the hose and nozzle this way loosen the pump to so there is no air pressure in the tank.
That should take care of the problem:thumbsup:
/ A RoundUp & Pump Sprayer Question #9
Part of the issue with roundup and it getting all globby like you said is in part because of the way it bonds to certain elements in the water. This is particularly true when using well water. This is the reason that they recommend mixing a small portion of sprayable AMS (Ammonium Sulfate) with round up. Not only does the N help the plant absorb it but it also helps keep the molecules binding with elements such as Ca or Iron in the water.
I've tried saving it and it will stay good for about a 3-4 days for me. Even shaking it up doesn't seem to help it reconsitute. To me I just make smaller batches than worry about trying to re-use and have to unclog a sprayer.
/ A RoundUp & Pump Sprayer Question #10
Even shaking it up doesn't seem to help it reconsitute. To me I just make smaller batches than worry about trying to re-use and have to unclog a sprayer.[/QUOTE said:
I think this is the REAL solution!!!
I guess maybe it is. I tried spraying tonight with some I'd mixed on Saturday and it was already showing some clogging at the screen. :duh:
I rinsed the sprayer and cleaned the screen so it'll be ready to go next time. Would my local farm store have the sprayable AMS? I have an Orschlin's in town and a Rural King a few towns over. If it's not too expensive I'll give it a try just to improve effectiveness.
/ A RoundUp & Pump Sprayer Question #12
The very first thing I do to any sprayer I use Roundup inside is to take a big Sharpie and mark "HERBICIDE" on the sprayer and then never use it for insecticide or anything else. Maybe you can wash that stuff out, but I just don't trust it. I never use a herbicide sprayer for insecticide. I know this has nothing to do with cleanup except to say that you have to be careful where you clean out a herbicide sprayer too. Rinsing out your sprayer in your yard will make an ugly dead spot. . . voice of experience here from years ago.:rolleyes:
Right you are! I only use this sprayer for RoundUp, and when I wash it out, the liquid runs down the concrete parking pad to the gravel drive. And that's where I'm spraying the stuff anyway. I have another sprayer I use for weed killers, and a pro sprays for insects once a month.
/ A RoundUp & Pump Sprayer Question #14
Just rinse the screen out. takes two seconds and is no problem.
To do it less frequently, store the wand with the nozzle pointing up. If I do this I can go through a couple gallons or so and not have to clean the screen.
I'll try the nozzle up trick next. I sprayed about a gallon yesterday and rinsed the sprayer and wand pretty well. To remove the screen you need to take the cap off the nozzle, but if you remove the nozzle assy first you can't unscrew the cap.
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
