A real turn off
/ A real turn off #1
oldernwiser
maine
KIOTI CK20 HST
Started my CK20 HST today. Temp. about 21 degrees out. Let it warm up for about 25 minutes. Worked lightly for about 25 minutes moving snow to open a path to the wood pile. Backed the tractor back into the garage and turned the key to the off position. NOTHING !!! Still running. Took several attempts with the key to finally get it to shut down. Did notice that none of the idiot lights lit up when turning the key to the off position. Any ideas as to what is going on?
Thanks ...
John
/ A real turn off #2
Spray some electronic cleaner in the switch. It may help make better contact.
Last week I had to use a heat gun to thaw out the ignition switch so I could get the key in. I then sprayed some WD40 in it.:D
/ A real turn off #3
check your battery connections also. I had that happen to me and that's what it was
/ A real turn off #4
On the off chance that someone doesn't already know it . . . . with our gasoline powered vehicles, turning the key off stops electric power from sending a spark to the spark plugs, so turning off electric power kills the engine. A gasoline engine is spark combustion. But a diesel engine is compression combustion; no spark plug, so turning off the electrical power does not kill the engine. You have to stop either the fuel flow, or air flow, to the cylinders to kill the engine. So I think the CKs have a solenoid that shuts off the fuel flow when the key is turned off. So it may simply be that the solenoid is stuck and can be freed up manually, or with a shot of something like WD-40.
/ A real turn off #5
Bird,
My Mahindra is just as you described. It also has a manual fuel shut off that can be pulled, down low near the platform, in case this situation arises.
/ A real turn off #6
Thanks ...
John
John
i have a ck20hst and had the same problem two years ago.... i had my dealer's mechanic look at the wiring but found no solution... now i just use the engine kill (red knob by the parking brake) switch and don't worry about it anymore
/ A real turn off #7
The key turns off an electric selonoid that shuts off the fuel. Maybe it's stuck. You can see it with the hood open.
My key switch also froze after pushing snow in a good snow fall. There was enough heat to melt the snow and it entered the switch and froze after parking the tractor. After doing what egon did to get it working again, I made a fix so it wouldn't happen again. I stopped at the local Lowe's store and picked up a rubber cup that you might use for the bottom of a kane or maybe table legs. It was 1 1/4 inch diameter. I cut the length down and then a small slit for the key to go through tightly. With the key in the switch, the open end of the cup just clears the dash. No more problems as it keeps the snow away from the switch top.
/ A real turn off #8
****, you solution my not be a "Rube Goldberg" but it merits a picture!
How did you attach the rubber cup?
--real turn off---funny play on words.
/ A real turn off #9
I'd say Victor is on the right track, my solenoid froze open and closed several times last winter. I had to pop the hood and just nudge it a little bit and it would operate one way or the other. I just sprayed it with a little with penetrating fluid and worked it back and forth and it hasn't stuck since last year.
Steve
/ A real turn off #10
see if you are getting power to the selonoid..... If not I have seen the timer that powers it go bad as well. Also check your connections and look for water or corrosion in this wireing. Use di-electric grease on these connections.
The way the timer works is, when the key is shut off the timer sends power to the selonoid for 7to 10 seconds to cut the fuel. This can be checked by unplugging the selonoid and checking with a test light.
/ A real turn off #11
I have a 1997 Lk3054 with the same problem. I have looked over the wiring schematic but it does not show a solenoid nor can I find one on the tractor. Where abouts would it be located?
/ A real turn off #12
MoKioti, on an LK3054, the key will not shut off the engine. You should turn the ignition switch to the off position when you're finished using the machine, then pull the engine stop knob (immediately to the right of the ignition switch). Pulling the knob out cuts off the fuel supply and stops the engine. The machine discussed in this thread operates differently than ours.
By the way, don't make the mistake of shutting off the ignition switch, leaving it off and still using th machine. The engine will continue to run but there will be no charge going to your electric system (like the alternator to charge the battery). Guess how I know this? :rolleyes:. Look no further than my signature.
/ A real turn off #13
Here's two pictures that I hope help. I used a 1/16 drill bit to make the small rectangular opening, 1/4 inch long, for the metal part of the key. Make sure it's centered in the cup. The key will fit in snug but I guess you could use silicone seal or other glue. The cup was just cut shorter to make it just clear the dash but go over the raised portion of the switch. I imagine it would also keep out dirt for those working the fields this summer.
I realize it's a crude setup but when I found my ignition switch froze, I was none to happy. The snow was piling up and needed moved. It's a quick solution to the problem but it works. After the snow is gone, I'll try to make something more professional. key 1.JPG
/ A real turn off #14
Oops, not being familiar with that particular model, I was thinking of the solenoid arrangement which my B2710 Kubota and lots of other tractors have. But what you just described is the same thing my B7100 had, except that instead of a separate knob, you just pulled the throttle all the way back, past a detent to shut off the fuel.
/ A real turn off #16
Thanks Ken, Now I won't have to charge my battery after running with the key off. By the way, you and I could have the same signature.
/ A real turn off #17
I may be wrong here, but it seems to me that the solenoid would operate in a "fail safe" mode. Power, (switch on), to open and let fuel flow, and then when there is no power, (switch off) it would close by way of a spring. If there is power to keep it closed, (and maybe there is), wouldn't this eventually drain the battery? Either way, it does sound like it is stuck.
My .02 - I can always learn.
Mini Skid Steer (A60352)
Mini Skid Steer...
New/Unused Electric Winch (A65583)
New/Unused...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
