A place to carry chains
/ A place to carry chains #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Here is my 1986 Ford 1910 with FEL and snowblower on it.
Finally got my christmas digital camera to work--just trying it out.
On the rear fender above the light is my cup holder made from PVC connectors epoxy glued to the plastic shroud around the light. I drilled several holes in the shroud and roughened the bottom of the PVC piece. There are 'drain' holes so water doesn't accumulate,
The arrow points to a Fleet-Farm tool box attached to the loader arm with 3 stainless steel worm gear clamps. I carry 2 chains, one light duty about 17' and the other 24'.
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 12/30/00 07:48 PM.</FONT></P>
/ A place to carry chains #2
The picture turned out good RCH.
I see that you've got plenty of the white stuff as well.
Happy New Year/w3tcompact/icons/smile.gif.
/ A place to carry chains #3
Rch, cool setup. How are you using those clamps. Do they go around the whole box?
/ A place to carry chains #4
Nice looking machine RCH. I think I see a reflection of the sky on your hood. Is that some sort of digital effect, or would you be waxing your tractor????? Good Photo!
Take Care,
Boots
A place to carry a shovel
On the left loader arm there is a short 6" piece of 1 1/4" PVC pipe and some squeeze clamps further forward to hold a shovel. I'm in the process of making a different style clamp forward so tree limbs are less likly to dislodge the shovel.
On the next picture you'll see a piece of tin on the upright of the loader. This is where the heel of my hand goes climbing off and on- it takes away that cooky-cutter edge.
RCH
Hand pad
See previous post re hand pad
RCH
/ A place to carry chains #8
Rch,
By the looks you have the right tool for the right job when it comes to winter.
Thomas..NH /w3tcompact/icons/wink.gif
/ A place to carry chains #9
Re: A place to carry a shovel
The view of the the country landscape sure looks peaceful and quite out there.
/ A place to carry chains #10
RCH,
Just going through the Photos to see what I might've missed. I like that shovel and the toolbox holder. Just one thing, wouldn't something
<font color=blue>...less likly to dislodge the shovel. </font color=blue>
also be likely to simply snap off the handle when the shovel gets caught?/w3tcompact/icons/shocked.gif Basically, the current setup works just like a shear pin on the PTO... easier to pick the shovel off the ground than off the hardware store's shelf /w3tcompact/icons/smile.gif
<font color=green>mark</font color=green>
Markcq2000, your point is well taken. The squeeze clamps I currently have are for holding tool on the wall and are just to flimsy - the two fingers have bent and cracked. In addition,they should be deeper. Also a longer piece of PVC pipe ( say, 4-5" more) would tend to hold better I think, especially when the loader is totally raised. At any rate, it's a handy place if it doesn't fall off and get run over and broken. These long worm gear clamps are strong and avoid drilling holes. I have a front and rear light mounted on the top cross member of the rollbar with them and they give you some adjustment. You can see one holding a piece of black toolbox drawliner foam as a glare guard on the forward facing light to the left of the driver.
RCH
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
10' DISC HARROW (A64276)
10' DISC HARROW...
2017 Chevrolet Silverado Z71 (A64127)
2017 Chevrolet...
2000 Jeep Wrangler 4x4 SUV (A61574)
2000 Jeep Wrangler...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
