A place to carry chains
/ A place to carry chains #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Here is my 1986 Ford 1910 with FEL and snowblower on it.
Finally got my christmas digital camera to work--just trying it out.
On the rear fender above the light is my cup holder made from PVC connectors epoxy glued to the plastic shroud around the light. I drilled several holes in the shroud and roughened the bottom of the PVC piece. There are 'drain' holes so water doesn't accumulate,
The arrow points to a Fleet-Farm tool box attached to the loader arm with 3 stainless steel worm gear clamps. I carry 2 chains, one light duty about 17' and the other 24'.
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 12/30/00 07:48 PM.</FONT></P>
/ A place to carry chains #2
The picture turned out good RCH.
I see that you've got plenty of the white stuff as well.
Happy New Year/w3tcompact/icons/smile.gif.
/ A place to carry chains #3
Rch, cool setup. How are you using those clamps. Do they go around the whole box?
/ A place to carry chains #4
Nice looking machine RCH. I think I see a reflection of the sky on your hood. Is that some sort of digital effect, or would you be waxing your tractor????? Good Photo!
Take Care,
Boots
A place to carry a shovel
On the left loader arm there is a short 6" piece of 1 1/4" PVC pipe and some squeeze clamps further forward to hold a shovel. I'm in the process of making a different style clamp forward so tree limbs are less likly to dislodge the shovel.
On the next picture you'll see a piece of tin on the upright of the loader. This is where the heel of my hand goes climbing off and on- it takes away that cooky-cutter edge.
RCH
Hand pad
See previous post re hand pad
RCH
/ A place to carry chains #8
Rch,
By the looks you have the right tool for the right job when it comes to winter.
Thomas..NH /w3tcompact/icons/wink.gif
/ A place to carry chains #9
Re: A place to carry a shovel
The view of the the country landscape sure looks peaceful and quite out there.
/ A place to carry chains #10
RCH,
Just going through the Photos to see what I might've missed. I like that shovel and the toolbox holder. Just one thing, wouldn't something
<font color=blue>...less likly to dislodge the shovel. </font color=blue>
also be likely to simply snap off the handle when the shovel gets caught?/w3tcompact/icons/shocked.gif Basically, the current setup works just like a shear pin on the PTO... easier to pick the shovel off the ground than off the hardware store's shelf /w3tcompact/icons/smile.gif
<font color=green>mark</font color=green>
Markcq2000, your point is well taken. The squeeze clamps I currently have are for holding tool on the wall and are just to flimsy - the two fingers have bent and cracked. In addition,they should be deeper. Also a longer piece of PVC pipe ( say, 4-5" more) would tend to hold better I think, especially when the loader is totally raised. At any rate, it's a handy place if it doesn't fall off and get run over and broken. These long worm gear clamps are strong and avoid drilling holes. I have a front and rear light mounted on the top cross member of the rollbar with them and they give you some adjustment. You can see one holding a piece of black toolbox drawliner foam as a glare guard on the forward facing light to the left of the driver.
RCH
