A little tractor project
/ A little tractor project #1
Devin 420
2003 farmpro 2420
Hopefully im putting this in the right place but here we go. So im getting around to fixing up my deceased fathers old tractor and its missing a bunch of parts its a 2003 ish Homier FarmPro 2420 2wd with 212 original hours, someone tried to steal the injectors by unbolting the nuts off the studs but they also pulled the fuel return banjo bolts off the injectors so im missing those parts as well and cut off the battery terminals, the cooling system is also trashed any tips on what all needs to be done just to try to get it to run for a short time.
/ A little tractor project #2
Glad to see you want to get it going again. It will take a lot of TLC to get her started but it can be done. I would start by making sure the engine turns free and is not locked up.
It still spins over with a breaker bar and the oil is black but looks good my father got his moneys worth out of it while he had it but its been sitting for the last 8 or so years non running
/ A little tractor project #4
If there is a Jinma dealer anywhere close you might contact them about parts...
good luck...
Thanks im gonna look around see if there is any
/ A little tractor project #6
You can also order online...you can also likely find a parts diagram on some of the sites...it can take a little searching...
I have looked around online but most of what im seeing is the entire injectors instead of just the banjo bolts and what not for the return sides of the injectors if I can get those bits it could run.
I did find 1 piece which can be seen someone dropped it onto the top of the injection pump so I threaded it back in
A lil update I found a complete set of injectors for 89 bucks apiece which is probably the best option since these injectors have been apart for who knows how long.
I cant quit afford em yet but once I can it wont be long and it will be in the woods doing what it did best.
Update time I havnt gotten around to the tractor as I wanted to we had a slight change in plans so hopefully before the end of the year I might can get back to it without much issues coming about.
Update time again while digging in the shed I found a old starter and injection pump for it and the wheel weights
/ A little tractor project #14
Nice find! Thanks for keeping us updated.
Update for anyone following along so for a while ive been saving up a bit of cash to put towards the tractor and so far things are looking up eventually gonna order the new injectors water pump a full gasket kit for the engine and a starter simply due to both starters I have are junk hoping to have the tractor operable for hunting season this year but im not 100% yet. Also had to move it to the back of our property due to storage issues so its in the weather which sucks.
/ A little tractor project #17
(y) Nice to see your breathing new life in iron some would have given upon.
Oh yah ive got a few parts to order todays plan was to see if the starter worked but it let the magic smoke out
Well its been a while and ive gotten zero work done on the tractor due to other issues and once again its on the back burner so I guess I will get to it when I can.
/ A little tractor project #20
I would worry that debris found its way into the engine. Do you have it turning freely. You might want to flush it out with diesel fuel - both top flush it out and help it spin freely.
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
Unused 2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2021 NM...
2017 PETERBILT 389 FITZGERALD GLIDER VOLUMETRIC MIXER (A67714)
2017 PETERBILT 389...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
